Hi,
Is there a way to make the sound of this sample better:
http://www.a3an.be/jelle/high.mp3
It sounds like the treble or something is a lil to high and that sounds bad on some places!
Thanx!!
there are lots of things you can do. fix the source by using an audio editor and reduce the high freq or lower the gain or add a filter.. or just lower the treb on the tv. cd player ,stereo etc.
what program you think is good for it?
can't get it nice with sound forge!
You'll want to use de-essing to remove this:
ess.mp3
Does soundforge have a de-esser built in? If not, you can download this VST plugin:
Use its graphic equalizer in 20 band mode.Originally Posted by Jelleke
thanks for the tip!
i downloaded the spitfish de-esser but can't get the same settings as you to remove that.
do you also use the spitfish?
i still have more low voice and can't get only the high
but i'm on my way! 8) -
1) Start by pressing the listen button :
2) Dial in the frequency where the "ssssss" sounds come from
3) Turn off the listen button to hear the de-essing applied to the audio.
4) Most of your high frequency noise is around the 5-7K mark
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 14:37 -
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 21:46 -
What is the difference between x264 AVC High@L5.1 and High@L4.1?
By Bonie81 in forum Video ConversionReplies: 9Last Post: 26th Aug 2013, 19:40 -
No Control for Bass / Treble on Sound Card
By rok2010 in forum Software PlayingReplies: 7Last Post: 9th Mar 2010, 17:02 -
ADVC-300 audio capturing oddities (treble/bass response)
By Wile_E in forum Capturing and VCRReplies: 2Last Post: 12th Sep 2007, 06:48
