    Sep 2007
    Australia
    I am trying ps warning: found sync code
    ps debug: es id=0xff format unknown
    ps warning: garbage at input, trying to resync...
    ps debug: es id=0xfc format unknown
    main debug: looking for decoder module: 28 candidates
    main debug: using decoder module "libmpeg2"
    main debug: thread 3856 (decoder) created at priority 0 (input/decoder.c:159)
    main debug: thread 4648 (decoder) created at priority 0 (input/decoder.c:159)
    main debug: thread 4672 (decoder) created at priority 0 (input/decoder.c:159)
    main debug: thread 4696 (decoder) created at priority 0 (input/decoder.c:159)
    main debug: thread 4720 (decoder) created at priority 0 (input/decoder.c:159)
    main debug: thread 4744 (decoder) created at priority 0 (input/decoder.c:159)
    main debug: thread 4768 (decoder) created at priority 0 (input/decoder.c:159)
    ps debug: es id=0xf6 format unknown
    main debug: thread 4792 (decoder) created at priority 0 (input/decoder.c:159)
    ps debug: es id=0xf9 format unknown
    ps debug: es id=0xf0 format unknown
    ps debug: es id=0xfe format unknown
    main debug: EOF reached
    main debug: closing input
    main debug: removing module "mpeg_audio"
    main debug: thread times: real 0m15.062500s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread 5032 joined (input/decoder.c:191)
    main debug: killing decoder fourcc `mpga', 0 PES in FIFO
    main debug: using decoder module "mpeg_audio"
    main debug: thread 5032 (decoder) created at priority 2 (input/decoder.c:159)
    main debug: thread times: real 0m0.000000s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread times: real 0m0.015625s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread times: real 0m0.015625s, kernel 0m0.000000s, user 0m0.015625s
    main debug: removing module "libmpeg2"
    main debug: thread times: real 0m35.828125s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread 4364 joined (input/decoder.c:191)
    main debug: killing decoder fourcc `mpgv', 0 PES in FIFO
    main debug: thread times: real 0m0.640625s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread 3856 joined (input/decoder.c:191)
    main debug: thread 4648 joined (input/decoder.c:191)
    main debug: thread times: real 0m0.625000s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread 4672 joined (input/decoder.c:191)
    main debug: thread 4696 joined (input/decoder.c:191)
    main debug: thread 4720 joined (input/decoder.c:191)
    main debug: thread 4744 joined (input/decoder.c:191)
    main debug: thread times: real 0m47.703125s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread 5036 joined (input/decoder.c:191)
    main debug: thread 4768 joined (input/decoder.c:191)
    main debug: thread times: real 0m0.578125s, kernel 0m0.000000s, user 0m0.000000s
    main debug: thread 4792 joined (input/decoder.c:191)
    main debug: Program doesn't contain anymore ES
    main debug: removing module "ps"
    main debug: removing module "access_file"
    main debug: thread times: real 0m48.953125s, kernel 0m7.515625s, user 0m6.562500s
    main debug: thread 4416 joined (input/input.c:412)
    main warning: refcount is 1, delaying before deletion (id=619,type=-7)
    main warning: unable to find parent!
    main: nothing to play
    to open movie and i get following message as it wont open
    I guess you are using vlc media player.
    Can you post some information about the video? identify the video and audio details with for example gspot or mediainfo.
    Sep 2007
    Australia
    Gspot says file type unknown and mime unknown??
    Sep 2007
    Australia
    I have d/loaded 140megs of movie so far and it still wont open in vlc.The bar moves as though it is playing but no movie or sound.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Does that mean it's still downloading? If so, you'll have to wait until it's fully downloaded. There are some apps that supposedly can play partial downloads of certain types, but it's not a sure thing it'll work.
    /Mats
  6. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    Also, you'd likely have to shut down whatever it is that you are using to download the file in order to open it in a media player. Most players don't like using files 'already in use' by something else.
  7. Mod Neophyte redwudz's Avatar
    USA
    It also depends what you are downloading it with. Some P2P apps can be set to download the first block with the information needed to display a partial video in a program like VLC. Without that block, the player may not have any reference to the video format and can't play it. MPEGs or DVDs are very hard to preview before they are finished downloading. AVI type files don't seem to have as much of a problem.
    Sep 2007
    Australia
    Thanks for the reply,I will wait until it has d/loaded then try.Just 500 megs to go
