Hi there, my problem is when i try to drag a .rmvb file to the playlist section, nothing happens (ie the playlist part is still blank).
Please someone help. Tks.
Sounds like it doesn't support rm files, at least not the version of your files. Try a different tool maybe. Look in the HOW TO - Convert section.
Google is your Friend -
Sounds like you need to add the rmvb extension to the list of files for the program to support.
Goto file extension mgr and on the line for real media add a comma and the rmvb extension. this sould fix the problem -
EO Video needs either Real Player or RealAlternative installed (it always uses external engine for RM/WMV/MOV via DirectX), then it will import RMs, maybe you'll also need to change file extension to .rm.
Winavi Stuck while converting Rmvb to avi.
By godbowen in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2008, 10:02 -
question about converting rmvb video file to avi video
By jimdagys in forum Video ConversionReplies: 5Last Post: 16th Nov 2007, 23:51 -
Converting .rmvb to avi
By rayrayleeroy15 in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2007, 09:04 -
Converting RMVB Into AVI with VirtualDubMod???
By sandman423 in forum Video ConversionReplies: 2Last Post: 14th Jun 2007, 20:21 -
Converting RMVB Into AVI with SUPER??? PLZ Help
By sandman423 in forum Video ConversionReplies: 18Last Post: 16th May 2007, 11:18
