I ripped a movie using Mac the Ripper software. Saved it to my Video_TS Folder on my hard drive. Opened Popcorn 3, selected Video_TS Folders, located my movie, click Choose, and got the message "The contents of this folder cannot be compresed" I clicked OK and the next meesage I got was "This is not a valid Video_TS folder it cannot be selected".
Any ideas on what I did wrong?? I follwed the Mac the Ripper instructions to the T so I thought. Thank you for your suggestions. I am on an iMac 2.14ghz 2gg of ram. Cheers,
Hi,
Thank you for the suggestions! Sorry it has taken a few days to reply have been away. I'll try what you suggested and let you know how I made out. I did let MTR create the Video_TS folder for me AND I only tried to extract the feature presentation npt the whole movie. I'll give this a go and let you know how I make out. Thanks again!
Cheers,
djranman
Just want to follow up to your suggestions. IT WORKED! Thanks for ALL the help. This help forum is GREAT! Much appreciated.
how to split contents of VIDEO_TS file to fit on CD discs
By strychnine81 in forum Newbie / General discussionsReplies: 14Last Post: 2nd May 2009, 09:03 -
How do you change the default View Setting for a folder's contents in Windo
By videopoo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Feb 2009, 17:41 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 13:59 -
how to delete the TEMP folder contents in windows?
By sumeshkri in forum ComputerReplies: 4Last Post: 3rd Sep 2008, 13:27 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 10:53
