Oh boy, these old TVs. I'm trying to connect RCA cables to a Zenith H20C34Y. It has a video and audio in in the back but I cannot figure out how to switch to Line In on the television... The only buttons on the tv itself are power, channel up/down, volume up/down, and caption. I'm not sure if the remote is the original one...'Concierge by Zenith' is what is written on it...either way it is no help because there are no buttons on it to switch to auxiliary video.
What to do? Does anyone know of any other way to try to change the input? I've tried different channels which would otherwise not be used like '0' but nothing works. I've also tried to turn on the tv with only the RCA cables plugged in...nothing. Am I screwed here?
You can search the web for remote codes for that TV.
http://uk.ask.com/web?q=tv+remote+codes&qsrc=999&l=dis&siteid=41439050
http://www.replacementremotes.com/tvcodes/index.htmRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
On the Old TV I used to have; I think I used "0" or "3". If that doesn't work you might have to find a Manual for that set.
-unfortunately, it doesn't override automatically
-i'm unsure of how the remote codes can help in this case...the remote i have works fine, it simply does not have any 'video' buttons
-zenith doesnt have the manual -
Most of the old Zeniths had "AV" inputs below Ch2 on the channel selector. Others used a "Video" or "Input" button on the remote. You will need a remote with the input button if that is the case and try all the Zenith programming codes.
auxiliary power connector on aiw2006?
By greenbag in forum ComputerReplies: 8Last Post: 2nd Sep 2010, 18:37 -
Need help troubleshooting video capture
By scorpio47 in forum Capturing and VCRReplies: 6Last Post: 13th Feb 2010, 02:48 -
How to get video on Television
By travelingteam in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2008, 14:57 -
Looking for info on troubleshooting of video streaming
By igorek in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2008, 13:25 -
Troubleshooting PC crash during video encode
By ontheteam in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2007, 13:01
