I have sony Vegas 7 and someone told me that it could convert movies to look like old black and white grainy films. I fly Very large WWI radio control aircraft and think it would be cool to convert my flying movies to this media look to make them more real looking and possibly put together a film of some kind. does anyone know how this effect is acheived? I am very new to editing but several years ago used to use adobe preimere for a while and catch on pretty quick.
thanks
Joe
Results 1 to 15 of 15
Right-click on your clip and choose Event FX. In the list of filters this is one that will give you an old cinema look.
There is a similar filter for Virtualdub from the MSU group : http://www.compression.ru/video/old_cinema/index_en.htmlRead my blog here.
thanks gunslinger i did that didnt see an old cinema looking thing so picked black and white and noise. didnt get the effect i really wanted but it did look old rofl. I just have the basic filters maybe i need to search for some. I got the filter from the virtual dub link but im probably correct in that it wont work in vegas
Read my blog here.
thanks gunslinger I appreciate the help I have been playing around getting familiar with the program and searching for plugins for the FX
hey guys I got it working the way I like and it really looks great just like an old movie. it also makes the models look just like the real thing and not a model. thanks for the help. now if only i can save it to stay looking good. for some reason it doesnt like my mov files and it did before but when i converted it to an AVI it really lost a lot of quality.
Joe -
im not sure ecatly what type it made right now i just finished rendering and it looks pretty good to me but boy they make large files.
I build fly and compete with large radio control planes. the current project is a 25 ft wingspan WWI bomber as was seen in the movie flyboys. when I am out flying I want to video the plane and then pull it into vegas and make it look like an old movie so that it looks like the real thing. if this thing wasnt so large I would post the original and the finished versions and you could see what I am doing. basically I am making a replica of a vintage biplane and editing the looks of the video so that you cannot tell it is a model and so far so good -
thanks yes it coes to around 265 megs. i am learning slowly. I got the editing to where I like it now will try to get the rendering to where I need it. I should have posted this for you to see earlier so that you know what I am working with but http://www.arizonamodels.com/videos/GothaMars.mov but that is the video I am working with and also the plane I am doing in 1/3 scale. it is for an event coming up next week in dayton and my plane project is for the next event which is in 2009. there are other movies here http://www.arizonamodels.com/videos.php but they are in ram format and I havent found a decent converter yet
yes that isnt mine but a non scale test they did as it was used in the movie flyboys. that one is 1/6th scale now imagine the same plane at 1/3 scale ie 26 ft wingspan flying like that with no people in the shot. then take that mov file pull it into vegas use the film effects and basically use the circa 1908 preset but add a little more on the scratcvhes and less on the flicker and jitters and you will see a full scale bomber come alive. thats what I did to that mov file that you saw. hehe you should grab it and try it to see what it comes too everyone is loving it. there is one called dogfight i did that too and it came to 300 megs as a wmv the gotha was shorter came to 21 megs. now if i can add special effects on the dogfight one as it is an in the cockpit view and you see the ends of the guns it will look like he is shooting.
i have fx vision lab studio with an additional 300 + presets to try and do the gun thing with later. for now i need to learn how to do more than just click a button or two in vegas. ( friend got out of video editing etc and gave me his discs so I have a bunch of things to mess with )
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 18:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00 -
Sony Vegas 9.0
By blecap in forum Video ConversionReplies: 36Last Post: 22nd Jul 2009, 01:21 -
Sony Vegas 7.0 to 8.0?
By bdr13278 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 21st Sep 2008, 21:58
