I have a need to produce a DVD for a school project, where the large projector cannot be moved/refocused and the screen is a large floor-to-ceiling screen.
In order to not to block the teacher/principal while speaking, I need to author a DVD whereby the video only occupies 1/4 or 1/6 of the whole "regular" screen real estate.
Is there a simple program whereby I could do such authoring (preferably having the ability to choose the size and location of the "windowed" video, and the rest of the "unused" area to be black?
Any recommendation and experience would be appreciated.
Thank you Midzuki. I tested a sample with this program and it worked. Two questions:
(1) it seems that the "ReduceBy" command only works for "2". I tried other numbers (like 3 or 4 for example) in hope of getting a different scale and it did not work.
(2) does this Avisynth program only work with *.avi files? I could not get it to work with any *.mpg files.
Thanks. -
You can load mpg files by either
1. Using DGIndex to create a .d2v file then loading this via avisynth (see the notes ate Neuron2.net for details), or
2. Installing FFDShow, setting it to decode mpg files, then using DirectShowSource in avisynth. If you choose the latter, make sure you are running Avisynth 2.5.8, and not 2.5.7.
Option 1 is the preferred option, but option 2 will work.Read my blog here.
Remove Small Section of Center Channel from Stereo Track
By EmpireStrikesBack198 in forum AudioReplies: 14Last Post: 31st Jul 2011, 13:48 -
Easiest way to "black out" a small section of video in an AVI file?
By johnny905 in forum EditingReplies: 7Last Post: 24th Mar 2010, 07:14 -
Blur small section of video
By zakman in forum EditingReplies: 4Last Post: 9th Mar 2009, 19:55 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
Burning small movie clips from camera(SD card) to dvd
By wesburnsco86 in forum Authoring (DVD)Replies: 6Last Post: 22nd Jul 2007, 16:09
