Hello all,
I am looking for some recommendations of software that will fit my needs. What are my needs you ask? As follows:
Must be able to create sub-menus
Must be able to handle AC-3 audio format
Easy to use - I am tech savvy but haven't dabbled much in dvd authoring before
Affordable - I'm looking around the $100 range.
My computer came loaded with Roxio myDVD9, but the version it came with doesn't support AC-3, I have to upgrade to get it. And of course Windows DVD maker.
Thanks!
Look under Video Helps "Tools". Right side of this window under "List".
https://www.videohelp.com/tools -
DVD-Lab & DVD-Lab Pro will do everything you want and more.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Capture Software Recommendations?
By Prince Valiant in forum Capturing and VCRReplies: 19Last Post: 18th Jun 2011, 00:59 -
Software recommendations
By ucime in forum Newbie / General discussionsReplies: 7Last Post: 20th Feb 2011, 01:47 -
software recommendations
By deftones in forum EditingReplies: 3Last Post: 12th Nov 2009, 20:33 -
Recommendations for Lightscribe labeling software
By DesertAvenger in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2009, 01:50 -
Newbie post - Recommendations for VHS-DVD Conversion.
By Mysticle31 in forum RestorationReplies: 20Last Post: 8th Jul 2008, 01:51
