I'm looking to get a new printer.
- It must be a color laser with 11x17 printing abilities.
- Full-bleed printing is highly desired (both 8½x11 and 11x17).
- Pantone color or Pantone matching would be nice.
Any and all suggestions are appreciated. Thanks.
I was looking for the HP 5550DN for our company, but decided to go with Konica CCP500. The printer will be in next couple weeks. The HP 5550DN has the ability to print 8 1/2X11 and 11X17. I hope it helps you little bit.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-3328071-409994.html
vcdlover -
I'm strongly considering this one:
http://www.bhphotovideo.com/c/product/505703-REG/Konica_Minolta_4039321_magicolor_7450...ge_Format.html
But still very much open to suggestions.
Thanks vcdlover, but I can't find anything online about that model. Is "CCP500" correct?
My own personal observation is that HP toner tends to be more distorted than Konica/Minolta toners. Agree, disagree?Want my help? Ask here! (not via PM!)
My bad. It is Konica CPP500.Originally Posted by lordsmurf
http://www.ikon.com/products/Printers/Color/IKON_CPP500.asp
We were going to go with HP, but the cost of maintaince and toner were too high. We end up leasing the Konica CPP500 for the price of the HP 5550DN. The leasing company provides us the toner and service. The CPP500 has the ability to scan and save the tiff files on the network and you can convert those to PDF. The printer you mentioned looks really good. The toner is much cheaper than the HP. Have fun hunting... -
Hi Smurf,
Sounds like you are looking for something graphics oriented. The HP CLJ5550 does allow you to change the colour space but will not give you the ability to build ICC colour profiles in either CMYK or RGB. HP's lower end colour machines use a PostScript 3 emulation. If you are in a Mac world or rely heavily on Adobe products for output then true Adobe PostScript 3 is going to be important to you. The only way around this is to add an external RIP (such as Fiery) but you drive the cost up quickly. You may want to check out the Xerox Phaser 7760. Many graphic designers use this printer for pre-press proofing. The colour is great and it gives you the control you need and Adobe PostScript 3 to boot. Expensive to buy and more expensive to run than the 5550.
If your print volume is low you can also consider some of HP's smaller desktop DesignJets, such as the 130nr. Ink is more expensive than toner but you get stunning output on a huge variety of medias as well as full bleed up to 24" wide and 150' in length.
If your print volume is high, check out HP's new CM8050/8060 with the Edgeline technology...full bleed 11"x17" colour inkjet @ up to 60 pages per minute. The ink is less expensive than toner. It also copies, scans, faxes, digital sender...you get the idea.
VH
color bleed
By unclescoob in forum Newbie / General discussionsReplies: 11Last Post: 1st Aug 2011, 17:09 -
Looking for Color Laser Printer reviews
By SCDVD in forum ComputerReplies: 5Last Post: 2nd Jun 2009, 00:43 -
color laser printer advice
By lordhutt in forum ComputerReplies: 6Last Post: 12th Apr 2009, 00:06 -
Advice for a new printer (multifunction inket or personal color laser)
By bobogs in forum ComputerReplies: 5Last Post: 30th Aug 2007, 11:51 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 10:05
