i'm sure this has been asked a million times on a million forums but there are so many diff answers and i still can't get mine to work ...![]()
basically i want to output my sky+ box into my pc (for recording / burning etc) and out to my monitor for viewing as i don't have (or wish to buy) a tv in that room
i clled sky who said no problem - simply use a normal tv cable (supplied) to connect sky+ to pc
so we ordered the additional box (multiroom) expecting the sky guy to connect it all up
he siad he could only connect it to a tv and we'd have to reconnect to a pc if thats what we wanted
so i tried a straight forward tv cable (supplied) but it wouldn't work
(nb i recoird tv from a normal arial using xp media centre - no problemo)
i've tried a scart to s-video input which doesn't work either
i've tried both normal cable and scart-svideo with settings on skybox changed to rgb but still no joy
i've tried sky and they now say they don't offer any advise regarding cnnection to a pc (even though they did prior to my new box - and the woman confirmed that the normal cable should work at the beginning of the call)![]()
please, please, please can anyone help as sky won't take the box back and i can't afford any more hardware / cables etc
thanks in advance
Results 1 to 11 of 11
Dose your tv (unknown) have video / audio outputs ?
If so , you should be able to connect the pc to those using a capture device (pci / usb / vivo) ... you may require some cables in order to connect it correctly .
If they said it should work with a particular cable , which they supplied , then its possible its defective and they should send a tech out to check ... I'm surprised those tech's they do send to install , don't do a complete test of the setup ... most don't .
Before calling them , repeat the setup according to instruction , and if it dose not work as it should , phone then .
Not knowing whats on the back of the unit ... what outputs are available ?
If a channel is known to be encrypted , it wont appear anyway on the pc , not without some help . -
i don't actually have a tv (watch terrestrial through my pc no probs) - had to borrow one for the guy to set it up
the cables fine as i tried it on to the tv i borrowed and it worked ok
if its encrypted does that mean it won't work ???
thanks for the response -
Your PC details says you have a Hauppauge WinTV capture card.
Regards,
Rob -
"aerial" output from your Sky box to aerial input on your card
and then re-scan for new channels some protected channels may not be recordable, not sure about that?
or a new card with dvb-s input, but that will only record the FTA and unprotected channels, unless you get one with a CAm (slot for your sky card, to authorise the channels).
ahh the naivety
i've tried rf output to pc but no joy scanning or manually entering rf output channel
Have you set the WinTV card to UK & PAL specs.
You may also need to repeat the scan under different conditions - when I had a WinTV card a few years back I think there were VHF and UHF scans.Regards,
Rob
Sky+ HD to PC
By BIGD22 in forum DVB / IPTVReplies: 4Last Post: 27th Sep 2011, 13:59 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 18:02 -
Record from Sky+
By village56 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2007, 12:24 -
Sky HD Box Help
By matw79 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Jul 2007, 14:05 -
USB SKY+
By fubsy in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2007, 06:43
