i have downloaded a movie, and i got subtitles for it in .srt form, with vlc i can just use the subtitles as well as the movie by selecting the right option in the open file menu.
my question is how can i to burn this movie to a dvd-r and try to play it in my dvd player (Sony dvp-ns63p) with the subtitles?
if i need to like re-encode or re-author or wtvr to get the subs working then how long would it take, and also im planning on converting the movie to DivX format as it is currently XviD so will this cause any problems with the subs?
btw i have looked through the other topics but they seemed to confuse me, i was just wondering if someone could clear things up for me
also i was wondering wether i would need to convert to DivX to play the Xvix on my dvd-player
any help is greatly appreciated
Your player should play the AVI as is, and to get subtitles, just name it the same as the movie, so you have movie.avi and movie.srt "side by side" on the disk.
If your player is silly enough to reject the XviD, try the fourcc changer to patch it to DIVX (DivX and XviD are so similar, that there's no reason for a player to play one but not the other).
If all else fails, run it thru AviReComp, but just as a last measure, as this will reencode, and lower the quality.
/Mats -
Originally Posted by mats.hogberg
1) GMC (Global Motion Compensation)
2) QPel (Quarter Pixel)
3) Packed bitstream
4) Resolutions greater than 720x576
5) Video bit rates greater than 2000 Kbps may cause various playback problems including the video not playing at all and the video playing but the audio not playing correctly. -
ok so i tried it and it worked but now the video is playing on the dvd player but theres no audio, i tried it on the xbox but it played really slowly and it was hard to tell if it worked on it.
any ideas on how to get the audio fixed?
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
adding subtitles
By dabud in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2009, 22:27 -
Adding subtitles
By tommcd64 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2009, 00:39 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Adding subtitles
By Avril in forum MacReplies: 14Last Post: 18th Jan 2009, 13:43
