Thanks, Soopafresh. I never noticed the 'Registers Dump'. A lot of good information there, especially with the latest version.![]()
Results 31 to 60 of 109
running Windows XP Professional x64 Edition
---------- RUN1PASS1.LOG
encoded 1749 frames, 42.95 fps, 1850.89 kb/s
---------- RUN2PASS1.LOG
encoded 1749 frames, 43.04 fps, 1850.89 kb/s
---------- RUN3PASS1.LOG
encoded 1749 frames, 43.42 fps, 1850.89 kb/s
---------- RUN4PASS1.LOG
encoded 1749 frames, 43.29 fps, 1850.89 kb/s
---------- RUN5PASS1.LOG
encoded 1749 frames, 43.32 fps, 1850.89 kb/s
---------- RUN1PASS2.LOG
encoded 1749 frames, 11.03 fps, 1826.37 kb/s
---------- RUN2PASS2.LOG
encoded 1749 frames, 10.97 fps, 1826.20 kb/s
---------- RUN3PASS2.LOG
encoded 1749 frames, 11.09 fps, 1826.37 kb/s
---------- RUN4PASS2.LOG
encoded 1749 frames, 11.08 fps, 1826.37 kb/s
---------- RUN5PASS2.LOG
encoded 1749 frames, 11.07 fps, 1826.37 kb/s
Running WindowXP Pro (32bit)
encoded 1749 frames, 64.67 fps, 1850.89 kb/s
encoded 1749 frames, 64.63 fps, 1850.89 kb/s
encoded 1749 frames, 64.82 fps, 1850.89 kb/s
encoded 1749 frames, 64.59 fps, 1850.89 kb/s
encoded 1749 frames, 15.60 fps, 1826.37 kb/s
encoded 1749 frames, 15.63 fps, 1826.37 kb/s
encoded 1749 frames, 15.60 fps, 1826.38 kb/s
Here is a blazing sempron running Window Vista home premium
encoded 1749 frames, 23.92 fps, 1854.10 kb/s
encoded 1749 frames, 24.15 fps, 1854.10 kb/s
encoded 1749 frames, 23.88 fps, 1854.10 kb/s
encoded 1749 frames, 18.71 fps, 1854.10 kb/s
encoded 1749 frames, 23.85 fps, 1854.10 kb/s
encoded 1749 frames, 5.64 fps, 1825.89 kb/s
encoded 1749 frames, 5.73 fps, 1825.89 kb/s
encoded 1749 frames, 5.66 fps, 1825.89 kb/s
encoded 1749 frames, 5.62 fps, 1825.89 kb/s
encoded 1749 frames, 5.65 fps, 1825.89 kb/s
From a Dell laptop running WindowXP Pro:
encoded 1749 frames, 40.75 fps, 1850.89 kb/s
encoded 1749 frames, 41.43 fps, 1850.89 kb/s
encoded 1749 frames, 41.81 fps, 1850.89 kb/s
encoded 1749 frames, 41.85 fps, 1850.89 kb/s
encoded 1749 frames, 41.03 fps, 1850.89 kb/s
encoded 1749 frames, 9.97 fps, 1826.38 kb/s
encoded 1749 frames, 10.32 fps, 1826.37 kb/s
encoded 1749 frames, 10.09 fps, 1826.37 kb/s
encoded 1749 frames, 10.09 fps, 1826.38 kb/s
timings are 3 3 3 8 2T, 300mhz.Originally Posted by graysky
@webster - thanks all all the data; table will be updated shortly.
http://encoding.n3.net <-- for all your DVD and CD backup needs! -
@graysky
Just a note, the Pentium D Presler processors are considered of having 2 cores (unlike the celeron D which only have one core)
Also the T2300 Yonah is also a dual core professor -
cool, thanks for the corrections
Intel Core 2 Duo E6600 (Conroe)
3060.1 MHz (9.0 x 340.0 MHz)
Intel P965/G965 rev. C2
XP Pro SP 2
encoded 1749 frames, 75.03 fps, 1850.89 kb/s
encoded 1749 frames, 79.84 fps, 1850.89 kb/s
encoded 1749 frames, 80.71 fps, 1850.89 kb/s
encoded 1749 frames, 79.00 fps, 1850.89 kb/s
encoded 1749 frames, 82.00 fps, 1850.89 kb/s
encoded 1749 frames, 18.99 fps, 1826.38 kb/s
encoded 1749 frames, 20.23 fps, 1826.38 kb/s
encoded 1749 frames, 20.15 fps, 1826.37 kb/s
encoded 1749 frames, 20.44 fps, 1826.37 kb/s
encoded 1749 frames, 20.43 fps, 1826.37 kb/s
cpuz.txtSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for the result -- will update soon
E6600@3.2GHz (8*400) + 2GB PC6400@800MHz (2-5-5-5-18 )
XPSP2 32-bit
EDIT:Code:---------- RUN1PASS1.LOG encoded 1749 frames, 88.41 fps, 1850.89 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 82.73 fps, 1850.89 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 85.06 fps, 1850.89 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 85.91 fps, 1850.89 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 84.67 fps, 1850.89 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 20.83 fps, 1826.38 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 20.77 fps, 1826.20 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 21.16 fps, 1826.37 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 20.76 fps, 1826.37 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 20.74 fps, 1826.37 kb/s
Uploaded registers dump for CPUZ.
cpuz.txttheHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here -
Cool, thanks for the data!
I have some additional systems I can run this on as well. D805, D915, D920, E6300, E4300@2.4GHz and an X2 3800+. I'll run them as soon as I get some time.
theHTPC.net
As of 20-Sep-2007, we have data on over 100 Intel-based systems and on over 40 AMD-based systems. There are a few trends I picked-up on while browsing through the database. I put them into a single table and color coded them to make them easier to see. If you see a trend I missed, lemme know and I'll add it to the table.
Request: we don't have a single example of a machine that has both WinXP and WinVista on it. If you have a dual-boot setup, it would be cool to see the difference the O/S makes. Another missing trend is a 32-bit O/S vs. the same O/S that's 64-bit.
On to the table:
Yellow: Nearly 1:1 increase by adding an additional processor to a dual-chip MB
Orange: Some operating systems seem to handle x264 more efficiently than others
Red: Insignificant gain by upping the DRAM speed by 50 %
Blue: For the most part, these chips scale in a pretty linear fashion
Green: Tighter/looser memory timings have a pretty insignificant effect
Purple: Keeping the same over-all clock speed using a different combo of multiplier and FSB can give pretty insignificant gains
Again, I only gave this a once-over look; please point out any trends you see that I missed and also don't forgot about the O/S request!
Thanks again to all who contributed!http://encoding.n3.net <-- for all your DVD and CD backup needs! -
My laptop has 2 drives: XP SP2 and Vista Home. I'll assume that fits the above close enuff and run the test on them. And it is an AMD processor.Originally Posted by graysky
be back in a while..... -
AMD TL-52
XP SP2:
encoded 1749 frames, 43.71 fps, 1850.89 kb/s
encoded 1749 frames, 42.38 fps, 1850.89 kb/s
encoded 1749 frames, 43.81 fps, 1850.89 kb/s
encoded 1749 frames, 41.41 fps, 1850.89 kb/s
encoded 1749 frames, 40.31 fps, 1850.89 kb/s
encoded 1749 frames, 10.23 fps, 1826.37 kb/s
encoded 1749 frames, 9.68 fps, 1826.38 kb/s
encoded 1749 frames, 8.68 fps, 1826.38 kb/s
encoded 1749 frames, 9.86 fps, 1826.37 kb/s
Vista Home:
encoded 1749 frames, 42.86 fps, 1850.89 kb/s
encoded 1749 frames, 43.65 fps, 1850.89 kb/s
encoded 1749 frames, 43.66 fps, 1850.89 kb/s
encoded 1749 frames, 43.62 fps, 1850.89 kb/s
encoded 1749 frames, 10.48 fps, 1826.37 kb/s
encoded 1749 frames, 10.42 fps, 1826.26 kb/s
encoded 1749 frames, 10.48 fps, 1826.26 kb/s
encoded 1749 frames, 10.46 fps, 1826.37 kb/s
encoded 1749 frames, 10.44 fps, 1826.37 kb/s
cpuzamdtl-52.txt -
Interesting data.
Fast is better it seems. More cores, even better.
A lot of OC'd processors. But that also makes you wonder about CPU temps and longevity of the CPU.
Just to post the site for the results again so you won't have to go back to a earlier part of this thread: http://www.techarp.com/showarticle.aspx?artno=442&pgno=0
And thanks for all of this, graysky, good info.
MacPro QuadCore
macproquadcore.7z
The 8 Core scales better than I thought - it's just about 2X faster
encoded 1749 frames, 116.60 fps, 1850.94 kb/s
encoded 1749 frames, 107.63 fps, 1850.94 kb/s
encoded 1749 frames, 118.46 fps, 1850.94 kb/s
encoded 1749 frames, 119.46 fps, 1850.94 kb/s
encoded 1749 frames, 119.47 fps, 1850.94 kb/s
encoded 1749 frames, 33.60 fps, 1829.01 kb/s
encoded 1749 frames, 35.11 fps, 1829.49 kb/s
encoded 1749 frames, 36.06 fps, 1829.30 kb/s
encoded 1749 frames, 36.06 fps, 1829.54 kb/s
encoded 1749 frames, 35.95 fps, 1829.37 kb/s -
@soopa - Thanks for the new data; what o/s is it running?
The O/S is posted towards the bottom of the CPU-Z reports. In this case, XP 64
Didn't see that... thanks.
No probs
Here's the exact same 8 Core Mac Pro as on the first page, except it is running XP 64
encoded 1749 frames, 140.27 fps, 1849.61 kb/s
encoded 1749 frames, 135.52 fps, 1849.61 kb/s
encoded 1749 frames, 141.15 fps, 1849.61 kb/s
encoded 1749 frames, 141.16 fps, 1849.61 kb/s
encoded 1749 frames, 136.51 fps, 1849.61 kb/s
encoded 1749 frames, 73.93 fps, 1835.13 kb/s
encoded 1749 frames, 74.62 fps, 1834.52 kb/s
encoded 1749 frames, 76.86 fps, 1835.16 kb/s
encoded 1749 frames, 74.47 fps, 1835.13 kb/s
encoded 1749 frames, 74.08 fps, 1835.18 kb/s -
Cool man... doesn't seem to be much of a difference between 32/64. I wish there was an avisynth64 and x264.exe that was 64.
Pentium 4, 2.8 GHz, hyperthreaded, 1 GB DRAMOriginally Posted by graysky
XP Pro (32 bit):
encoded 1749 frames, 25.95 fps, 1850.89 kb/s
encoded 1749 frames, 26.13 fps, 1850.89 kb/s
encoded 1749 frames, 25.88 fps, 1850.89 kb/s
encoded 1749 frames, 26.03 fps, 1850.89 kb/s
encoded 1749 frames, 26.09 fps, 1850.89 kb/s
encoded 1749 frames, 6.14 fps, 1826.38 kb/s
encoded 1749 frames, 6.14 fps, 1826.37 kb/s
encoded 1749 frames, 6.11 fps, 1826.37 kb/s
encoded 1749 frames, 6.10 fps, 1826.38 kb/s
encoded 1749 frames, 6.12 fps, 1826.26 kb/s
Vista Ultimate (32 bit):
encoded 1749 frames, 18.83 fps, 1850.89 kb/s
encoded 1749 frames, 19.90 fps, 1850.89 kb/s
encoded 1749 frames, 19.44 fps, 1850.89 kb/s
encoded 1749 frames, 19.27 fps, 1850.89 kb/s
encoded 1749 frames, 22.02 fps, 1850.89 kb/s
encoded 1749 frames, 4.81 fps, 1826.37 kb/s
encoded 1749 frames, 4.49 fps, 1826.37 kb/s
encoded 1749 frames, 4.89 fps, 1826.37 kb/s
encoded 1749 frames, 5.59 fps, 1826.37 kb/s
encoded 1749 frames, 5.68 fps, 1826.37 kb/s
cpuz.htm: cpuz.zip -
graysky- Avisynth 64 exists (and a handful of plugins, including Dgdecode), but I don't believe there's an X264 64bit exe.
Another interesting thing to try is setting the maximum amount of memory that Avisynth can allocate. This is done through the SetMemoryMax() commmand, usually at the top of the script. On jobs that need a lot of RAM, this change can make a significant difference. Memory intensive plugins include MVtools.
SetMemoryMax(512) #or whatever is half of the actual ram installed in a system
LoadPlugin("etc.....) -
@jag - thanks for the data set. Can you report the multiplier and FSB, mem timings and settings, and northbridge chipset also?
@soopafresh - got a link to avisynth64 and dgdecode64? Too bad there aren't any x264-64.exe's out there.http://encoding.n3.net <-- for all your DVD and CD backup needs!
x264 Encoding Help
By Trismegistus in forum Video ConversionReplies: 14Last Post: 28th Apr 2012, 09:55 -
Follow-up: x264 CPU usage--threads vs. instances
By Calidore in forum DVD RippingReplies: 26Last Post: 12th Feb 2010, 20:24 -
HD x264 CPU benchmark - compare different CPUs encoding the same file
By graysky in forum ComputerReplies: 108Last Post: 4th Dec 2009, 14:45 -
Best CPU chart for x264 HD Video Encoding Performance
By INFRATOM in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Feb 2009, 23:55 -
x264/720p CPU requirements
By RB4891 in forum Media Center PC / MediaCentersReplies: 3Last Post: 15th Jun 2007, 08:31
