I need to capture to PC the speech and music from a lot of personal sound cassette tapes.
Can anyone suggest free apps that will capture the sound from cassette tapes (Probably as WAV files) with good tape noise reduction and suggest free apps that will convert the WAV to MP3.
Several years ago I used an old version 3.2 of Total Recorder that would capture the WAV files but it seems to be incompatible with Windows XP and seems to give an install error. I used an old Version 2.80 of Winamp with an MP3 plug in to convert the Wav files to Mp3. Not sure if it will work with Windows XP. I still have these old apps.
Thanks all
Results 1 to 10 of 10
Well Totalrecorder is up to version 6.1. I've had it since the 3.?? version and don't recall paying to upgrade at any time. Perhaps they'll upgrade for you, too. Meanwhile, Audacity ought to do what you want, including filtering and levelling and noise reduction and even MP3 encoding, all for free!
Mp3DirectCut records strait to mp3. CDEX is pretty good too. Both good for free.
Thanks for the many helpful tips.
Just curious why any free app also does encoding to MP3.
I thought encoding to MP3 was copyrighted. I remember reading something about LAME whatever that is.
Thanks all -
Encoding is not copyrighted, but encoder is. However, like everything else, there is lots of them free around (not original code).
Big Ted
All OK.
I can now record to MP3 using Total Recorder and monitor what I am recording on the PC speakers.
Thanks all
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01 -
Lnux video capture apps ... suggestions?
By Nitemare in forum LinuxReplies: 14Last Post: 9th May 2013, 22:35 -
Are there are other apps like gotsent? Looking to convert mkv to mp4
By AndyD in forum Video ConversionReplies: 42Last Post: 8th Sep 2009, 07:09 -
JVC GR-DVM828 Not showing up in any capture apps
By jammery2k in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th May 2008, 12:03 -
What free Apps for screen capture other than CamStudio
By Firewire60 in forum Software PlayingReplies: 0Last Post: 21st Feb 2008, 18:29
