Sorry if this is the wrong website for help.
I just bought a Sony Handycam DVD508. The only input is USB.
Is there any way to burn my old VHS home movies onto this camera or do I need to go get another camera with RCA inputs?
You would be better off getting a dvd recorder.
Google is your Friend -
The USB input is for DIGITAL video, not analogue. I assume it works as if you are using it as an external drive that will only accept video files (presumably in a compatible format). According to Sony ( http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&stor...8&Dept=cameras ) it doesn't have analogue inputs. In fact, looking at the spec, it appears to have very little going for it! You'd have been better off buying a MiniDV camcorder (or, as Krispy Kritter says, a DVD recorder).
Old Sony Handycam to PC
By cincy_kid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jul 2011, 00:05 -
Want to Upgrade my Sony Handycam
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 9th Jun 2011, 11:34 -
Sony DCR-PC108E Handycam
By ckbasak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 13th Jan 2010, 13:57 -
Problem with Sony Handycam!!
By FrontierGander in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Aug 2009, 22:23 -
Sony Handycam - DCR-HC20E
By nzmikey in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 05:17
