Does there exist a program that can analyze & compare two or more DV captures of the same VHS tape (possibly captured using different VCRs, differently-tweaked tracking, etc) and automatically identify dropped frames in the "main" (reference) capture that might have been successfully captured in the other? Preferably, in a way that makes it easy to visually compare the two ranges, and copy a block of frames from the second into the first if appropriate?
Likewise, one BIG problem I encountered with the video I captured is that the hi-fi audio track had a loud buzz unless I adjusted the tracking to the point where the picture became unstable, so I ended up having to capture it with mono audio instead. Is there any program that would let me record the tape's hi-fi audio with the tracking optimized for it, then automatically resample it to the temporal rate of the mono track & ultimately replace the mono track with the resampled hi-fi track?
Results 1 to 1 of 1
HowTo deal w/ nasty "audio streams have diff sample sizes" errors in WAVs!!
By KneeRow in forum User guidesReplies: 0Last Post: 25th Jul 2011, 12:43 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 22:34 -
Was it the iphone that replaced the word "program" with "application"?
By yoda313 in forum Off topicReplies: 6Last Post: 16th Mar 2011, 08:52 -
What are "Source" and "Transform" filters in MPC?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2008, 21:20 -
Any Program to "blank out" or "black out" a portion of
By mbextreme in forum EditingReplies: 6Last Post: 18th May 2007, 04:04
