I have Windows xp and sometimes (about 10%) of the time, after computer startup, the mouse doesn't respond. If I unplug the mouse and then plug back in, it will always solve the problem, so it is not a serious problem. I am just curious why this happens.
Could be a loose connection. Might be time to change the mouse.
also check in bios to see if its set for allow USB mouse and keyboard. thats assuming you have a usb mouse. if its PS/2 mouse then make sure the settings are correct in bios for that too. it will be very obvious in the bios if you look around what im talking about.
I have same problem in Win2k with PS2 mouse except unplug and replug doesn't fix it but reboot does.
@bevills1
Your ps2 connector has to support plug and play for it to work without a reboot. Probably most do but some don't.
@jimdagys
If it is a usb, you could try another port. If by chance you are using a ps2 I'd switch to a usb I've never had a mouse problem since going with an optical usb.
Circle or arrow to point out highlighted player
By adrian1472 in forum EditingReplies: 1Last Post: 11th Feb 2012, 00:45 -
Circle around or arrow to point out highlighted player
By adrian1472 in forum LinuxReplies: 0Last Post: 10th Feb 2012, 22:49 -
Mouse problem = looking for new mouse.
By Stealth3si in forum ComputerReplies: 14Last Post: 12th Nov 2011, 05:25 -
Could kinnect or move lead to more pc ports of classic mouse adventure game
By yoda313 in forum Off topicReplies: 0Last Post: 22nd Oct 2010, 11:17 -
Hmmm....That's New - Down arrow key....my computer beeps
By hech54 in forum ComputerReplies: 4Last Post: 26th Jul 2009, 02:06
