i been joining xvid's into one file with virtual dub for awhile now and had no prob as long as its only two parts but i tried dong more then 2 parts i get:
As far as i can tell when i use gspot they have the same stuff as far as audio, video, framerate, and res size.. what i'm trying to do is make a episode dvd disc with 4 episodes on it..
i read on here not to join at xvid stage but at author stage.. i have tda 1.6 i tried that before but i had issues. A audio error pop up saying each mpg file had different audio or something... i prob could author them one at a time then import them back in tda 1.6 as dvd video source but wouldn't it be too large to fit on a dvd-5 dics? as far as shrinking down so it will fit on the dvd-5, losing video quality is a factor. Any suggestions or is this my only resort?
	You can try patching the non standard fps file with AVImaster.
 http://www.thozie.de/AVIMaster.zip
 Avimaster -fv29.97 InputFile.AVI OutputFile.avi
	Try using AVIFrate to change them both to the same frame rate. Make sure Scale, Rate, and FPS are all the same.
 See also:
 https://forum.videohelp.com/topic335041.html#1739932
 https://forum.videohelp.com/topic335041.html#1740045
  VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35
  Joining 1080p MKV with SD XviDBy TheCoon in forum EditingReplies: 7Last Post: 7th Nov 2009, 09:56
  Avidemux - joining two Xvid clips resulting in one Divx video, why?By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 29th Apr 2009, 17:10
  Joining Xvid files with MP3 audio (VBR) without loosing synch?By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 20:19
  joining xvid problemBy aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 05:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
