I've been trying to split an .ogg audio file with no loss in quality by importing it into a video in Virtualdubmod and using the selection to pick out the bits I want.
Unfortunately, the import bar on Virtualdubmod goes all the way to the end and then crashes the application every time. I've tried altering the Decoder settings on ffdshow between Tremor, libavcodec and disabled with no luck.
I've also tried every application I can find that claims to losslessly split .ogg files, but they either reencode or just can't do it. The .ogg file itself plays fine in VLC Player.
Any advice appreciated.
Well, for anyone else with this trouble in the future, the problem was caused by the .ogg file not having a proper header (it was a capture of a stream). Virtualdubmod doesn't like that, it seems.
VLC Media Player was able to output the problem file as a new .ogg stream without losing any quality. This new file did have a proper header and worked with Virtualdubmod with no problems.
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 16:34 -
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
Adding .ogg audio with ffmpegx
By wesg in forum MacReplies: 1Last Post: 5th May 2010, 20:16 -
Audio converter for AAC, AC3 and OGG
By MasterRoshi in forum Newbie / General discussionsReplies: 12Last Post: 20th Feb 2008, 17:54 -
VirtualDubMod Splitting problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2007, 18:20
