A SVCD can contain from about 35 to 80 minutes video/CD(740 MB on a 74 min/cd and 800 MB on 80 min/cd)
From what I understand a Svcd can only be 800mb it 2 work, Iam wrong? Please post any ides or thought on this.
<font size=-1>[ This Message was edited by: ckxd69 on 2001-07-21 15:55:48 ]</font>
Firstly you have to understand what a SVCD is defined as. If you check around - including the "What Is" Guide on this website, you'll find out that a SVCD stream is mpeg2 in a framesize of 480x576 (PAL @ 25fps) or 480x480 (NTSC @ 29.97fps) - however the determination of file size is dependent on which birate you encode or capture at. If you use the max. bitrate of 2.600kb/s you will get about 35mins on a 74min(650MB) 43min with a 80min (700MB) CD. If you lower your bitrate the file size will be smaller.
If a SVCD had in the end a file size of many GB you would still be able to play it (for example from your hard drive).
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-21 16:44:00 ]</font> -
Thanks 4 the help, But could u play that SVCD (that is a few gbs) on a standalone dvd player?
The answer is "NO" as the media can only hold up till now 845MB (+90min CD-R's). However there have been reports that people have used a DVD-R(W) recorder and DVD-R media (4.6GB) to record SVCD's on to. If this works (that would mean over 4hours of SVCD on 1 disk) I cannot say (yet).
Thanks got that all cleared up, I didnt even know there were +90 min cd-r's, how much r they?
http://www.inc-tech.com/
I have ordered from here 90 min. CDR's, there still fairly new, I have had prob with my HP 8X32X4 9200I Burner my friends plextor 16X40X12 works great with nero over burn. I haven't yet got nero to work with my burner to burn 90 min. I can put nearly 50 minutes of SVCD per disk. They play great in my Sampo DVD Player Stand Alone. I am open for suggestions if anyone has tried anything.
GOOD LUCK -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Not that much more expensive than 80min CD-R's - however I have only seen them in 25er packs. You should also see that your CD-R writer and DVD Player can take these 90+ CD-R's.
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-22 20:27:02 ]</font>
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 03:41 -
Embedded attached picture (covert art) max size
By Brazil in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2009, 06:56 -
Max Hard Disc Size on PS3?
By SCDVD in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2008, 04:11 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 09:02
