HVR -
So if I want to be as accurate as possible with my entry points, what method would you recommend? I have found one method to work. I load my source in TMPGEnc, and using the Manual VBR setting, I set my entry point frames to be GOP I-frames. I then divide these frame numbers by 23.976 to get the time code in seconds, which I set in my XML file. This seems to work very precisely. I have found that if I encode in anything other than Manual VBR, VCDImager complains that it can't find the entry point exactly, and sometimes places the actual entry point as much as six seconds from where I requested. So the Manual VBR seems the best option. It might work just as well if I set the I-frames to be simply I-frames (and not GOPs as well) but I haven't verified this.
- digvid
Results 1 to 1 of 1
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 08:52 -
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 09:21 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
