Results 1 to 14 of 14
    Sep 2006
    does anyone remeber these? i have one that i think is dead,when i boot up
    it shows the bios ver. the processor speed then hangs, any ideas
    thanks, black cloud
    USA
    I've given a couple away and I still have one at home which I will probably junk out. Is it just showing a partial page then hanging? Immediately after the memory and the CPU, it should show the hard drives and the optical drives. If it's stalls on the drive display part, it may not recognize one of the drives. If so, unplug all drives except the boot drive and try it again.
    That sounds like a hardware problem with one of the drives or your boot drive may be messed up.
    If you had a Linux or Windows PE boot disc, you could set the BIOS to boot from your optical drive and unplug all other drives including the boot drive and try it. That would tell you if the motherboard is working.
  3. I've got one in the spare room as well. Have you tried replacing the BIOS battery and resetting the BIOS? Also, try disconnecting the floppy drive and the cd/dvd drive - I have seen similar symptoms caused by a dead drive. It might also be worth trying a replacement power supply, I guess that's just as likely to go on an older machine as on a newer one. Good Luck.
    May 2003
    Peterborough, England
    Do you get any error beeps? I've found problems with faulty memory can cause this. Remove the memory and see if it does the same.
    Sep 2006
    thank you for all replys,
    what i have done is replaced the old (good) one with one i bought (faster)
    and i get bios ver and proc speed then it just sets there.
    I put old proc back in and everything works fine.so,i think(in my little mind)
    that the proc is dead.
  6. Or the motherboard doesn't support it. Did you check the motherboard makers site to see if the processor you bought is supported or supported after a Bios upgrade?
    Sep 2006
    the motherboard(ga-71x) supports 500 to 1000 mghz.
    i went from a 650 to 950 and got the hang time.
    as for a bios upgrade i havent tried that.
  8. Member Heywould3's Avatar
    Apr 2002
    always on the move
    maybe it needs more power? can you up the vcore volts in bios? does the bios have a manual and auto setting for the cpu? might have an early overclock engine that is set wrong?
    EDIT: i just rememberd. i have an old socket a computer with an amd 950 chip also. hers died and i thought it was the PS but it ended up being the chip. so who knows.? could be dead. but that chip and setup is so old you could prolly get a whole new computre with those settings off ebay for 100 or less
    EDIT: 2.. i jsut rememberd this too.. on my chip there was a set of dip switches taht needed to be set for the multiplier and voltage not bios settings. i bet thats the issue.
    this should help
    Model Number Frequency L2-Cache FSB 1 Multiplier Voltage TDP Socket Release Date Order Part Number
    Athlon 600 600 MHz 256 KiB 200 MT/s 6x 1.75 V ??? Socket A, Slot A June 5, 2000 A0600AMT3B
    Athlon 650 650 MHz 256 KiB 200 MT/s 6.5x 1.7/1.75 V 36.1/38 W Socket A, Slot A June 5, 2000 A0650AMT3B/A0650APT3B
    Athlon 700 700 MHz 256 KiB 200 MT/s 7x 1.7/1.75 V 38.3/40 W Socket A, Slot A June 5, 2000 A0700AMT3B/A0700APT3B
    Athlon 750 750 MHz 256 KiB 200 MT/s 7.5x 1.7/1.75 V 40.4/43 W Socket A, Slot A June 5, 2000 A0750AMT3B
    Athlon 800 800 MHz 256 KiB 200 MT/s 8x 1.7/1.75 V 42.6/45 W Socket A, Slot A June 5, 2000 A0800AMT3B/A0800APT3B
    Athlon 850 850 MHz 256 KiB 200 MT/s 8.5x 1.7/1.75 V 44.8/47 W Socket A, Slot A June 5, 2000 A0850AMT3B/A0850APT3B
    Athlon 900 900 MHz 256 KiB 200 MT/s 9x 1.75 V 50 W Socket A, Slot A June 5, 2000 A0900AMT3B/A0900APT3B
    Athlon 950 950 MHz 256 KiB 200 MT/s 9.5x 1.75 V 52 W Socket A, Slot A June 5, 2000 A0950AMT3B
    Athlon 1000B 1000 MHz 256 KiB 200 MT/s 10x 1.75 V 54 W Socket A, Slot A June 5, 2000 A1000AMS3B
    Athlon 1000C 1000 MHz 256 KiB 266 MT/s 7.5x 1.75 V 54 W Socket A October 31, 2000 A1000AMS3C
    Athlon 1100B 1100 MHz 256 KiB 200 MT/s 11x 1.75 V 55.1/60 W Socket A August 14, 2000 A1100AMS3B
    Athlon 1133C 1133 MHz 256 KiB 266 MT/s 8.5x 1.75 V 63 W Socket A October 31, 2000 A1133AMS3C
    Athlon 1200B 1200 MHz 256 KiB 200 MT/s 12x 1.75 V 66 W Socket A October 17, 2000 A1200AMS3B
    Athlon 1200C 1200 MHz 256 KiB 266 MT/s 9x 1.75 V 66 W Socket A October 31, 2000 A1200AMS3C
    Athlon 1300B 1300 MHz 256 KiB 200 MT/s 13x 1.75 V 68 W Socket A March 21, 2001 A1300AMS3B
    Athlon 1333C 1333 MHz 256 KiB 266 MT/s 10x 1.75 V 70 W Socket A March 21, 2001 A1333AMS3C
    Athlon 1400B 1400 MHz 256 KiB 200 MT/s 14x 1.75 V 72 W Socket A June 6, 2001 A1400AMS3B
    Athlon 1400C 1400 MHz 256 KiB 266 MT/s 10.5x 1.75 V 72 W Socket A June 6, 2001 A1400AMS3C
    You need to set the multi to 9.5 and voltage to 1.75 for the 950 to work. it is currently set to 6.5 1.7/1.75 which means the voltge settings are likely ok just change the Multi
    P.S. if i remember corrently those slot A chips were very overclockable. i think i was able to get 1.4 maybe 1.35 outa mine. but hey whats an extra 400mhz?
    Sep 2006
    hello, and thank you for your response
    are these settings for a slot a, or socket a processor?
  10. Mod Neophyte redwudz's Avatar
    USA
    Those appear to be Socket A CPUs, at least by the part number. I don't know if both socket types have the same CPU core, though.
  11. Member Heywould3's Avatar
    Apr 2002
    always on the move
    if you look close it says both socket and slot A the page i got that from had a seprate chart for either but they are the same settings
    Sep 2006
    i found a bios upgrade that is for a cpu upgrade to a 900, on my bios
    i couldnt find anywhere to manualy change the settings.
    so, i'll try this and see what happens.
    thanks again for all the help
  13. Member Webster's Avatar
    Are you trying to change the multiplier and voltage from the BIOS? if you are, I think you misunderstood what Heywould3 wrote. He meant you need to physically change the multiplier and voltage setting on the motherboard by changing the dipswitch (or jumpers) on the motherboard.
    Edit....Just found out that the Gigabyte GA-71X autodetect CPU voltage so there are no jumpers.
  14. Member Heywould3's Avatar
    Apr 2002
    always on the move
    its strange that your board says it supports 500 -1000 yet you need bios update to allow fo a 900mhz chip? as webster says your boad is auto detecting.. but that doenst mean that there isnt some sort of jumper on the board to allow it to do it.. if you dont have your manual then go to the website and download it and look under cpu settings.
