Hi everybody,
please help me with next described problem:
I purchased new graphic card ATI Sapphire Radeon HD 2900 XT 512MB GDDR3 AVIVO, and have installed
it to the totally new PC.
Unfortunatelly there are no longer not supported best software ATI Myltimedia Center (ATI MMC).
Officially responded from ATI/AMD, because I have opened trouble tickedt at ATI/AMD. They suggested
me, that use 3rd party software, because nothing software packed with ATI cards, only drivers and
game demos.
I'm using ATI ViVo cards and VirtualDub for 10 years without any problems until now. This is first
card with many problems. When I start VirtualDub and switch to the the capture mode, then I must
set video standard from NTSC to the PAL (European), it is OK. But when I want change resolution
and color compression settings in capture pin then freeze whole PC and operation system WIndows XP Professional SP2. There is possible hard restart only with reset button (SW restart and CTRL+ALT+DEL is not function). Of course these all in WDM DirectShow mode, because WDM VFW VideoForWindows mode is not function. There is green video vindow only.
I have tried and used these all for many years on old PC PIII-450Mhz/Radeon 9000 Pro Vivo, and older systems in past and all these are working perfectly without problems.
I have tested original Catalyst drivers from ATI install CD and newest drivers from the web, but there are not difference.
My hardware is:
CPU Intel Core 2 Duo E6850 3GHz
MB MSI P35 Neo Combo
RAM Corsair TWIN2X 800MHz DDR2
Sound Blaster X-Fi
HDD Seagate 7200.10 series 500GB and WD5000AAKS
PSU Enermax Infiniti 650W (with DXX 6+8 pin power for graphics)
I'm experimented for 3 weeks, but I'm very worry from it. It is not working correctly.
Please help me. Thank You.
I have exactly the same problem. Is there some solution for us?
Anyone?
I can't see anything in the specs that says this is a video capture card. I assume since it has crossfire technology that you need to buy a separate HD tuner card.
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 11:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 21:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 15:52 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 13:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 16:25
