    Sep 2007
    right now i have a dell 8400 with the following specs...
    P4 3.2Ghz
    1.5 GB DDR2 RAM Kingston 200mhz
    XP 32-bit
    evga Nvidia 8600GTS
    Creative SoundBlaster X-FI XtremeMusic
    500w Antec EarthWatts Power Supply
    Xbox 360 HD-DVD drive
    42" Vivio 1080p (DVI>HDMI)
    i've updated just about everything now and it's time to get a new computer.. i've been basically using this as an htpc so now i want to keep as many components from the 8400 as i can for my new htpc...
    using all this mostly...
    160gb SATA internal
    500gb and 250gb My Book Externals
    Nvidia 8600GTS
    currently i'm not worried about recording or anything.. my main concerns are to beable to watch hd-dvd's and all my other movie and music files smoothly...
    i'd like to spend less then 400.. any help would be appreciated as i don't know which cases.. cpu's. motherboards.. etc... i should use....
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    What processor would you like Intel Core 2 Duo or AMD Dual Core AM2? Does the speed of the processor matter to you? I'd say for $400.00 you may not be able to get the fast processor, ram & mobo.
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I tried to stay within your $400.00 budget. Here's a system using a Intel Core 2 Duo system using the E6550 Conroe 2.33ghz processor.
    Intel Core 2 Duo E6550 Conroe 2.33GHz 4M shared L2 Cache LGA 775 Processor, $175.99
    http://www.newegg.com/Product/Product.asp?item=N82E16819115030
    GIGABYTE GA-G31MX-S2 LGA 775 Intel G31 Micro ATX, $78.99
    http://www.newegg.com/Product/Product.asp?item=N82E16813128061
    A-DATA 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Memory, $41.99
    http://www.newegg.com/Product/Product.asp?item=N82E16820211064
    SILVERSTONE LASCALA 10 CS-SST-LC10B Black Aluminum front panel, Media Center/HTPC, $99.99
    http://www.newegg.com/Product/Product.asp?item=N82E16811163033
    Subtotal was $396.96.
    Here's a AMD AM2 Dual Core system:
    AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 Processor, $169.99
    http://www.newegg.com/Product/Product.asp?item=N82E16819103773
    GIGABYTE GA-MA69GM-S2H AM2 AMD 690G HDMI Micro ATX AMD Motherboard, $78.99
    http://www.newegg.com/Product/Product.asp?item=N82E16813128056
    The HTPC case and Ram is the same from up above.
    Subtotal is $391.96.
    The shipping cost would run your budget over to about $420.00 or so. That Silverstone HTPC case would be able to use a ATX or MICRO ATX motherboard. I'm sure other members will have other suggestions for you. IMHO with $400.00 you can get a good decent system up and runnning.
    Sep 2007
    thanks for taking the time to do all that...
    i don't know much about the difference between amd and intel.. my main concern is just making sure i get a dual processor.. i'd like to get the maximum speed i could possibly get but obviously with my budget i don't expect anything top of the line...
    also i forgot to mention i already have 2gb of 6400 ddr2 ram so that doesnt need to be in my budget....
    i found a good deal at fry's but it looks like i just missed the deall..
    http://cdn.travidia.com/rop-sub/17533558
    i like the case though.. thanks again for the help.. this was alot of help.. im actually going to buy everything in about 2 weeks from now.. so im going to do as much research as i can and this was a great starting point....
