Is there any way to get the ADStech DVDXpress DX2 to record MPEG-2 with a bitrate higher than 4,000kbit/sec? According to the datasheet for the chipset it uses, the chip itself is capable of 10,000kbit/sec VBR. I'm guessing that ADStech's marketing department or management had the "brilliant" idea of arbitrarily limiting the bitrate to 4mbit/sec to ensure that 2 hours of captured video would fit on a 4.7-gig DVD.
I've read allusions to manually editing the registry to get it to use higher bitrates, but so far I haven't had much success. I changed m_nSelVidBitRate from "4000000" to "8000000", and changed szbitrate='4.0mbit/sec' to szbitrate='8.0mbit/sec' in the m_sCustomVideoParams key and tried capturing again, but the entire computer froze hard a little over 14 minutes into the capture. Oops. Also, the manual hints that it uses VBR, but in the 'custom' string, I noticed that vbr=0... which doesn't quite give me warm, happy feelings of comfort...
Well, I got an official response from ADStech. They said that the 4000kbit/sec statistic is an observation, not a coded limit. Apparently, in "best" quality mode they aren't actually limiting the bitrate. Rather, 4000kbit/sec is the most they've actually observed the Micronas codec chip actually USE.
I'm not 100% sure that I buy it completely, but it's not inconceivable. I've done embedded hardware/software development, and I know that the pdf brochures for quite a few large-scale chips are (cough, cough) "embellished" a bit by marketing departments who don't necessarily understand the chip itself. Case in point: pre-3D video cards whose specs might have been given as, "2048 x 1440, 32-bit, 240hz refresh" where in reality, you could never actually get 240hz refresh at anything above 800x600, and the card only had enough RAM to do 24-bit color at 1280x1024.
In any case, it's moot. I decided to spend the extra hundred bucks and buy what will hopefully be the last NTSC capture device I'll ever have to buy: a Pyro. Besides giving me total encoding freedom via software (that, at the specs provided by the DVD Xpress, could be done in near-realtime anyway), it's firewire-DV, so I'll never, ever have to screw with a proprietary capture driver again.
ads dvd xpress dx2
By joselito in forum Capturing and VCRReplies: 0Last Post: 29th Aug 2009, 12:21 -
DVD Xpress DX2 on Vista
By dolfan43081 in forum Capturing and VCRReplies: 31Last Post: 20th Jul 2008, 21:56 -
Newbie problem with ADS Xpress DX2
By jimmy_fowler in forum Capturing and VCRReplies: 2Last Post: 1st Jan 2008, 09:09 -
Major Problem with DVD Xpress DX2
By AcidFMHQ in forum Capturing and VCRReplies: 0Last Post: 22nd Aug 2007, 07:02 -
Can DVD XPRESS DX2 convert my cassettes to digital as well?
By spodekmodek in forum Video ConversionReplies: 4Last Post: 8th May 2007, 20:38
