    Sep 2007
    Australia
    Hey,
    I was just wondering if someone had a second hand breakout box (BOB) for liquid edition. I just want to be able to see full screen output on a third monitor: T.V. to check colours. I use pinnacle liquid edition 6. I live in Perth Australia.
    What goes wrong in BOB's? Is there another solution? Is there a reputable place to buy BOB's.
  2. Look for a pinnacle movie box deluxe. It functions the same way as bob. It works for Liquid 6.1, 7 and also Pinnacle Studio.
    Sep 2007
    Australia
    Thanks dun4cheap, How does the movie box work. If I want to preview a clip full screen on a T.V. while I had both other comp monitors running- will it work? Can you preview your clips off the timeline with the effects you have applied.
  4. It will work just fine. The Movie Box Deluxe and Bob are brother and sister devices. The Bob has more input and output options like Dolby 5.1 and Component out. From within liquid or studio you can enable the MBD or Bob. As for your two monitors, just set them up as an extension of your desktop. In Liquid the User interface should automatically expand to the second desktop.
    At the bottom of the liquid window there is a button to enable bob or MBD as a preview device. The other cool thing about bob and mbd is that they can preview yellow slices without having to be rendered.
    Sep 2007
    Australia
    dun4cheap thank you so much for your help!!!
