Hello,
i'm newbie in area: converting DVD into divx/xvid.
I use Total Video Converter. I click "new task" then "Rip Video" DVD.
Then i select output format (xvid) and so on.
If i click "convert" the application creates for every "DVD Chapter" single file.
See here:
http://img212.imageshack.us/my.php?image=snap1km5.png
How to convert all this "chapters" into 1 xvid-avi file?!
regards
topek
I have never used total video converter so I can't answer directly. I'm sure there is an option somewhere to output to one file. Keep looking in the options settings.
You're alternative should be virtualdub. I believe if you go to file-append avi segment you'll be able to merge all the avi's into one file.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Try with AutoGK or FairUse Wizard .....I too have never used TVC..... or ConvertxtoDVD is one that many prefer.....
" Who needs Google, my wife knows everything"
By callmeking in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 19:51 -
Question about which AVI type in Total Video Converter plays in DVD player
By jimdagys in forum Video ConversionReplies: 2Last Post: 22nd May 2008, 08:37 -
Total Video Converter conversion
By jimbb in forum Video ConversionReplies: 8Last Post: 29th Feb 2008, 02:47 -
Total Video Converter filesize limit
By ashoun in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:40 -
Problem with Total Video Converter
By supaduparocka in forum Video ConversionReplies: 0Last Post: 16th May 2007, 07:26
