Hello, I have a Sony Nicam 127cm Rear Projection tv and it needs some help. My kids have put a crack in the front layer of the two layers of screen and i would like to replace this screen. I have contacted sony direct and they have said the parts for this model are unavailible any more and i would like to know if someone knows what i can replace this screen with or does someone know of a parts department that will have a replacement for this tv.
The model number for the tv is kprs52sn1. I have run out of places to look and hopefully someone can help. Thank you
	The outer "layer" of screen, is just a protective covering. You can remove it from the TV and not affect the TV's performance. Of course it won't be there to save your TV the next time the kids are acting up.
 Your local TV repair shop would likely be your best bet. See if they can contact their part suppliers and maybe find one in the system.Google is your Friend
	HELLO KRISPY
 The outer layer is not a protective cover and it does affect the tv's performance but thank you for your advice. I have contact all my local repair shop but they cannot help with my problem
	At a stretch, try eBay and look for an identical model that is defunct but useful for salvage. I've done this for camcorder LCD displays and saved a lot of money. Of course, they are much smaller(!)
	My appologies. All of the rear projection TV's that I have seen, have a removable protective "screen", which is cheaper and much easier to replace in case of accidents. Guess Sony didn't get the memo. Google is your Friend
  sony Vpro 10 "video longer than sound" sony hdr-cx116e, part IIBy cesarin in forum EditingReplies: 16Last Post: 11th Oct 2011, 07:20
  Some ghosting on part of render with Sony VegasBy sevenofone in forum EditingReplies: 35Last Post: 28th Feb 2011, 14:25
  NICAM to two stereo tracksBy redishdog in forum AudioReplies: 0Last Post: 27th Aug 2010, 11:48
  how can i edit a small part inside a movie and make that part look bigger?By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32
  NICAM channels bundled together after converting DVD videoBy come_mon in forum Video ConversionReplies: 5Last Post: 27th Nov 2008, 20:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
