I have a Phillips DVP3960 going into a proview rx326 using hdmi, but the hdmi option stays grayed out.....any ideas?
Stays grayed out where? In the dvd player menu or the TV menu?
Google is your Friend -
The TV menu will likely stay grayed out until it senses a signal on the HDMI interface. Have you changed your dvd player video setup to use HDMI output?
I have the same problem, my TV screen is black all the time with the HDMI cable.
Any ideas ???? -
You should start your own thread...not threadjack. Try reading the rules.Originally Posted by catbus
Also, your problem is different. His menu option was greyed out, you are saying your TV screen is black (no picture).
DVD players typically output video from only one source at a time, which typically defaults to composite/S-Video. When changing to a new output, you have to change the DVD player video settings. The settings and process vary from player to player, but it should be outlined step by step in the user manual.Google is your Friend
Phillips DVP-5990 - HDMI problem?
By Ai Haibara in forum DVD & Blu-ray PlayersReplies: 5Last Post: 3rd Jan 2009, 03:18 -
HELP phillips dvd5960/37 hdmi to dvi
By mobstatus in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Mar 2008, 00:51 -
Phillips 5982 no 5.1 over HDMI :(
By Fearnot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Mar 2008, 23:49 -
Unhackable Phillips DVP3960/37?
By seticat in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Nov 2007, 02:30 -
Phillips Upconvert DVP3960/37
By LanxS in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 00:28
