i have a dvd filled with avi videos and one (1) mpg video. i put the dvd disk in my dvd player and only the mpg file can play. i guess then in order to see all avi files i need to make a conversion of them to mpg. question apart from how, would be to figure out what kind of mpg file is that which can play without any probs on my dvd player...
where do i begin?
the main goal is to convert and place all videos on a dvd disk to watch on my dvd player!
thanx
how cheap was it?
you could always make it a present,
and go for a toshiba
http://www.plaisio.gr/product.aspx?catalog=15&category=900&product=967262
i also believe the greek make Crypto is good.
in short you seem to have bought crap.
i can't find specs though.
if you want to convert your files to the format recognized on your disk.
it's mpeg1.
you can use tmpgenc plus which is free for mpeg1 encoding,
and play around with it.
or you can do mpeg2
and author DVDs.
search guides.
gl
DVD to AVI Or MPG
By AeR0 in forum DVD RippingReplies: 10Last Post: 4th Mar 2010, 19:59 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
avi/mpg splitter
By MasterThomasMI in forum EditingReplies: 3Last Post: 10th Nov 2007, 11:44 -
MPG clips to AVI
By Marcel555 in forum Video ConversionReplies: 2Last Post: 2nd Nov 2007, 18:07 -
mpg to avi with AutoGK
By Whatever_works in forum Video ConversionReplies: 5Last Post: 14th Jul 2007, 21:07
