i took the whole day authoring a SVCD using TSCV (0.83 R1). when i finally succeeded i was more then very happy. after testing it on WinDVD 3.0 i burned it to a disk, and this little disk i put in my stand-alone DVD player.
after loading a bit i see my menu, and one second later the movie starts. this i didnt ment to happen, but everybody makes mistakes, however, when i started using my chapter shortcuts, it moved to totally inaccurate places on my SVCD. all around the 60th minute. im sorry i cant give you the exact numbers right now, cuz its connected to a in-use TV set (i can post em later if you want them). the points where ment near minute 23,46 and 70, offcourse minute 0 too, but that one works allright.
if i load my cd in WinDVD (also the physical disk), it works allright.
also the menu is correct when i create a CD with Nero.
The video was created with cce 2.5, the audio with tmpg, and muxed with bbmpeg.
i attached the .xml file, the cce settings, and the .cue file. cce settings is copied from the internet, i had DC precision on audio, and aspect at 4:3
please tell me what i did wrong.
NidoranZ
sorry, here are the files
http://nidoranz.ssihost.com/cce.png
http://nidoranz.ssihost.com/cd.htm (should be the .cue)
http://nidoranz.ssihost.com/tscv.htm (should be the .xml)
Inaccurate Rip Using dBpoweramp CD Ripper
By Nitro89 in forum AudioReplies: 3Last Post: 5th Jun 2015, 12:03 -
When "official" soundtracks are "inaccurate"...?
By takearushfan in forum Newbie / General discussionsReplies: 10Last Post: 17th Jan 2012, 16:03 -
VOB2MPG chapter split - inaccurate?
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 16th Dec 2010, 14:43 -
MediaInfo Inaccurate?
By newpath in forum Video ConversionReplies: 3Last Post: 22nd Apr 2010, 01:08 -
Inaccurate file splitting
By Blå_Mocka in forum Newbie / General discussionsReplies: 11Last Post: 13th May 2008, 04:19
