i currently have a cd-rw writer and a dvd rom drive installed in my computer. i have purchased a new dvd writer would it be advisable to remove any of the other drives if so which one.
there is a spare slot which would mean all three of the drives could fit but could three drives decrease performance of my computer?
thank you
Personally , its aka the cd burner .
If your going to install more drives , you better consider upgrading the psu to above 450watts . -
I second that.
Two reasons:
1. Some PC games when copied will not play on a burner but will do fine on a Rom drive
2. If you are into backing up your DVD collection I would rather use the cheaper DVD rom to decrypt then the writer.Listen to me now and believe me later
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
Set up a TV Station!
By SatStorm in forum Video Streaming DownloadingReplies: 2Last Post: 1st Aug 2008, 16:18 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39
