Results 1 to 10 of 10
    Feb 2006
    having problem with delta farce dvd movie
    my back up dvd freezes after the credits finish and wont go to the title screen
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Failure at the end of the DVD usually means crappy blanks/media.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Or if you actually have an original (commercial pressed) disc, then it is faulty/damaged...exchange it.
    Google is your Friend
    Dec 2006
    Here,where do you think?
    Most likely a media issue as hech54 stated..but what proggy r u using?
    " Who needs Google, my wife knows everything"
    Feb 2006
    i used dvd fab decrypter
    and tried dvd fab hd decrypter 3180
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Well... guess it has to be dragged outta ya.....
    What "brand" of media are you using ??
    What are you shrinking it with ?
    But what hech54 stated, failure or problems at the end (outter edge) of a disc is usually bad media.
    Feb 2006
    i do have the original it plays fine
    my backup just freeze after the credits end
    i even tried copying the backup useing a dvd+rw, still does the same thing
    Feb 2006
    maxell dvd-r
    and dvd shrink
    Dec 2006
    Try better media,and I'd use IMGBurn to burn it.....Verbatim or TY media are what most recommend.....
  10. Banned
    Jun 2004
    Brand names mean nothing most of the time.
    DVDInfoPro will give you specific info on the MID of the disc, what company actually made it before maxell or whoever put their label on it.
    http://www.digitalfaq.com/media/dvdmedia.htm
    Which i believe certain info/parts are outdated.
    But there are a lot of variables, some media burns better on some drives, worse on others, there are firmware updates for burners to make them more compatible with various brands of dvdr's, programs used, ect ect ect.
    Verbatim is a consistent brand for quality & you can usually always find 50 packs on sale between BestBuy, OfiiceMax, ect.
    I pretty much use verbatim dvd+r exclusively.
