... frames?
Hi,
can anybody help me with this. I have the following situation:
- 30 short recordings, each about 1-2 min. long (format: mpeg-1, 30 frames / sec., about 80 MB per min., resolution 640*480)
- all clips are similar, so using settings I saved already for pass-1 and pass-2 are sufficient to me
Now, in manual proceeding, I need to perform the following steps for deshaking:
1.) open the video and load settings
2.) run pass-1
3.) add 30 frames of another movie (so that the ending of the movie isn't cut off in pass-2)
4.) run pass-2
5.) trim video (cut the unnecessary new 30 frames at the beginning of the movie)
6.) save avi
My problem is: In Dubman, I can specify step 1.), 2.), 4.), and 6.), but I have no idea how to specify 3.) and 5.). Do you know what I mean? I don't want to let the edges be cut, so I really need these steps. Is there any solution to let it all be made in batch mode?
Thank you in forward!
	hm, I realized now I probably can step 3) before step 1), results seem to be OK. Still, I don't know how to proceed. WHen I let Virtual Dub save an AVI using the settings with step 1 and then take the result video for step two, I get the arrows within the video!
 Does anybody have experience how to accomplish Batch Mode for Deshaker? Thank you!
	The missing thirty seconds can be fixed by creating a black 30 second clip of the same type as you video and put it at the beginning of your video.
 I think it states htis in teh readme of the filter.
	wonder how you do the scripts in dubman .. very confused how to do it ! .. do i need to specify each file for ????Originally Posted by Speed Demon
 i got those arrow thingy in the first step
 could we do multiple files in a series of processing for deshaker ????
  How to Remove Camera Shake from iPhone 4S Videos (Batch Deshaker Script)By preshing in forum EditingReplies: 1Last Post: 17th Apr 2012, 23:35
  virtual dub, mts and batch processingBy cesardeuve in forum Video ConversionReplies: 16Last Post: 13th Oct 2011, 16:08
  convert to avi in batch modeBy volam1 in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 05:04
  Video Fade In/Out Batch ModeBy quxote in forum EditingReplies: 11Last Post: 1st Mar 2009, 19:41
  how to batch file in virtual dub?By warlock110 in forum Video ConversionReplies: 2Last Post: 17th May 2007, 01:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
