Results 1 to 9 of 9
  1. i have some real odd problems here i`m sure are my
    newbie failings
    Ie: Using any version Cyberlink power dvd , my problem is playing
    BR and HD-DVD movies with full menus , i cant get past the
    menu screen with options etc . like scene / extras / play
    selection , the mouse wont access these . How do i access
    these so i can start the movie or view the extras ?
    Another problem is , with some flix ,
    using same mentioned player , i cant get video on my
    Sony tv when i use to play this flick , but i do on my pc
    monitor ,
    i have read the manual to no avail
    i have a intel 2.4 dual core , intel DG965SS main board ,
    Nvidea GeForce 8800 GTSoc
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by ian curtis
    i cant get past the menu screen with options etc . like scene / extras / play
    selection , the mouse wont access these . How do i access these so i can start
    I'm amazed you got to the menu. Did the manual say this would work
    for BR and HD-DVD movies ? What is your monitor? Which drive?
    I was thinking all hope was lost.
    Feb 2004
    Australia
    http://www.cyberlink.com/english/support/bdhd_support/system_requirement.jsp
    Update your system specs ... from amd old to new intel specs , would help .
  4. Member edDV's Avatar
    Mar 2004
    Hmm, interesting where they made the cut, NVidea 7600GT and minimum Pentium 4
    541 (3.2G). That is minimum.
    Burden is on Cyberlink to prove it works. Ask for money back.
  5. " I'm amazed you got to the menu. "
    im not sure why your amazed ? Was this because you
    seen my old specs ? i`ve updated them now in profile
    Yes the manual said this would work , i quote
    " When you insert your DVD movie disc, after playing the warning
    messages, your DVD Movie Main Menu will appear in the video window.
    You can locate the Menu Pad by clicking on the outer arrow button on your
    PowerDVD Main Control Panel. The directional arrows allow you to select
    the options on your main DVD movie menu, and then you can click on the
    center button to enter your selected menu option. "
    i cant see these directional arrows for the life of me
    i use a TTX monitor , and a Sony 60 inch HDTV as my 2nd monitor
    Via a dvi out from my video card
    i hope this helps
    Cheers
  6. Member edDV's Avatar
    Mar 2004
    You are out there on the fringe. Tell us what Cyberlink says.
    I think I'm good on CPU, RAM, 7600GT and HDCP monitor as well. If Cyberlink gets yours working, I'll buy one too.
    http://www.kiva.org/about
    Oct 2005
    666th portal
    try clicking on unlock player panel in the lower right and then the option to open menu/number pad should be in that lower right spot.
  8. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    "Any" version of Power DVD won't work. It has to be version 7 with all of the latest patches.
    There is also the issue of having an HDCP compliant video card and monitor/TV. If for example, your TV is compliant, but your monitor isn't, that could cause issues.
    I also remember reading somewhere that PowerDVD has issues anyway. They announced Blu-Ray and HD-DVD playback support before any drives for the pc were even available.
    And I thought I read somewhere else about all of this only "working" properly with Vista. But I can't find the review at the moment.
    Google is your Friend
    Oct 2007
    Speaking of PowerDVD7, does anyone know a way to open the player panel (for A-B repeat etc.) in the full screen mode. It can be done on all earlier versions by left clicking the screen. Cyberlink wrote back that it can't be done. Seems weird. Am I tweaking?
