I have a number of WMV exports from Photo Story 3 that I would like to merge into a single WMV file. Is there a tool that can do this without re-encoding the clips?
The clips have all been generated using the same PS3 output quality/profile which uses the audio codec WMA9.2(mode:Quality VBR) and the video codec WMV9.1 Image(mode: Quality VBR).
I have tried using AsfBin but the GUI version complains of an audio block misalignment and the command line version seems to generate garbled video after the first input file.
Thanks!
-SJR
Soopafresh - thanks a lot. Based on your reply to a related post from someone else I did try out AsfBin, but have not had much luck. GUI version of AsfBin says audio is misaligned, command line version produces garbled video for everything after the first WMV - I tried a number of the switches to no avail. I can only surmise that the WMV codec used by PS3 is not joining well with AsfBin. Am I using AsfBin wrong/Any thoughts?
Thanks! -
Yes. I would quote the Sesame Street song - "One of these WMV files is Not like the Other" :P
That's probably it, I'm afraid. You could create an .ASX playlist and "virtually" join the files that way - that is if you plan playback on your PC. Perhaps some other devices can read .ASX playlists.
How to join (merge) HD m2ts files?
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Feb 2011, 14:58 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 17:57 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 23:58 -
how can i join VC-1(WMV-3)files
By sumeshkri in forum Video ConversionReplies: 3Last Post: 26th Oct 2008, 01:21 -
merge / join 2 MPG2 files
By joelore in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2008, 23:14
![Computer details: WinXP
Celeron 2.4Ghz
60GB
256 MB DDR
SiS 305 32MB AGP
[ieee1394/firewire port on MB]
Coby DVD-515
[model unknown]
IOMagic MagicWriter 32x10x40
Via P4PB Mainboard
Comp](/images/buttons/computer.gif)
