I've installed Mac The Ripper, FFmpeg and the three extra bits, but there is a problem. My friend DOESN'T have an intel chip Mac, and I'm wondering if this is the bit that's playing up. I read older posts and tried to follow the lead to another site, but whatever was there then isn't now. \ Many thanks for any sugestions / Migs
The error message says:
Encoding started on Sat Sep 8 14:59:35 NZST 2007
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
FIXME:Hardenabling SSE and SSE2 without detection
CPU: Intel (Family: 6, Stepping: 6)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0x28000
MPEG: FATAL: EOF while searching for sequence header.
Video: Cannot read properties.
Exiting...
Have you tried the same source files on your friend's Mac?
If so, then the likely difference is a bug in the Intel version, but not with the Intel chip itself. -
You would likely get more answers in our Mac forum. Moving you.
And welcome to our forums.
You might want to trash the app and reinstall. Go here and follow the instructions:
http://ffmpegx.com/download.html
You should delete the library/application support/ffmpegX folder before doing the reinstall, so everything is clean.
I have a ppc G4 and the app works great. The account you install from MUST be admin level, because the installer uses SUDO. -
I think there are different binaries for PPC and Intel. Probably best to doenload the proper version for your CPU.
Opening video files from computer
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 16:55 -
Intel to debut 6-core gaming chip (aka video editing)
By stiltman in forum ComputerReplies: 18Last Post: 5th Mar 2010, 16:09 -
Intel details future graphics chip at game conference
By stiltman in forum ComputerReplies: 6Last Post: 5th Dec 2009, 22:17 -
Intel Cuts Some Quad-core Chip Prices by 40 Percent
By Soopafresh in forum ComputerReplies: 0Last Post: 20th Jan 2009, 13:41 -
wmv file - opening freezes computer
By armingate in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2008, 19:14
