Hi,
My DVD player will play avi, and I am wondering how would I burn the avi's with a root menu without converting each avi like you would if converting to dvd, ... , so it takes shorter time? The burning program I use in nero. Is there different burning software that will do this or how will nero do put a menu in?
THanks soo much!
You'll need to check for divx ultra certified players .
And the rest : http://labs.divx.com/MenuBuilder -
...in other words, if your DVD player isn't DivX Ultra certified, you'll either have to live with whatever basic menu your player may provide for browsing through the files, or author a video-DVD.
how do i create a multi page root menu.
By visualhippocracy in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2011, 15:02 -
Hoe to create a DVD menu with link to AVI files
By OggO1984 in forum Newbie / General discussionsReplies: 3Last Post: 14th Dec 2009, 16:01 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 02:40 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37 -
DVD menu with avi without converting to DVD?
By Ghtpua in forum Authoring (DVD)Replies: 1Last Post: 5th Sep 2007, 20:17
