  1. Member Seeker47's Avatar
    Jul 2005
    This particular clip was a VOB etc. that I extracted myself using SHRINK. Shrink itself can play this clip o.k..
    I already tried GOM Player (but maybe not the absolute latest version . . . ) and the answer there was NO.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
    All software players can play pal. It must be something else, does gom player include a dvd/mpeg2 decoder for example?
    Try use vlc media Player, media player classic or kmplayer instead.
  3. Member Seeker47's Avatar
    Jul 2005
    Thanks a lot, Baldrick. You were right: it must be a limitation of Gom. I should have tried VLC first. No problem playing it there. It seems like a good idea to keep at least 2 or 3 players installed, for cross-checking purposes, as long as each can be kept from exclusively grabbing all the media file associations, as they often try to do when you install them.
