Soryr if this has been asked to death but i just could find the answer. Can you point me to an easy to use capture software taht can capture from a VIDEO IN composite source and Line IN (Creative Soundblaster Line IN) source. Im using a PowerView video capture card WDM drivers are installed. This is a Win2K3 box, P4 2GHZ, 1GB Ram.
We tried using Ulead Visual Studio 6 but it seems to have probs recording sound and there appears to be no compresison codecs and so 5 secs of video capture is like 60MB. There is no alternate codec selection. Im dloading v11 but am not hopeful. I do hjave several codecs installed on the PC
	What format do you want to capture to?Originally Posted by quantass
 VS6 is very old. VS11 should work. A 2GHz P4 is borderline for realtime MPeg2 capture. The more you compress during capture, the more CPU you need. With VS11 or a free program like VirtualdubMod, a common tactic is to capture to uncompressed or huffyuv, edit and then encode non-realtime. A 2.8 GHz or better can realtime capture to MPeg2 at 7000 Kb/s vbr or so. At 4000 Kb/s you may get rebuffers and lost frames.
  Best video capture software? Is AVI better for capture? Is TV screen betterBy johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17
  VHS capture software?By TYLER08027 in forum Capturing and VCRReplies: 7Last Post: 6th Dec 2010, 15:52
  What software will capture MPEG-1 ?By Palmer Eldritch in forum Capturing and VCRReplies: 17Last Post: 4th Jan 2010, 19:12
  Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29
  From VHS to Capture Card to Capturing SoftwareBy TV107 in forum Capturing and VCRReplies: 1Last Post: 9th Nov 2008, 19:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
