I have some .Wmv files that i cannot fast forward or jump to ......
I know they have to be indexed and i have several tools that can index the files (ex. Windows Media Encoder) but it takes soooo long time, 2 hours or so.
Does anybody know a faster way so that i can fast forward or just jump to the part of the video i want to ???
Thx in advance (-:
Download this, place Asfbin.exe and Reindex.bat in same folder as your WMV files and double click Reindex.bat to run.
asfbin1.6.1.703.zip -
THX (-:
this really works. Just tested it and it did it in less than 2 minutes.
Thx for this help .... -
Thanks guys ,
The similar problem at side was also solved using the method described.
Regards. -
Hello Friends,
Actually i have tried the given software and somehow it is not fixing all the WMV files I have. I tried it on one of my clips around 300MB in size and it created another files with the prefix "ReIndexed~same filename.ext" . But when I tried to play the similar file in JetAudio or Windows Media Player. It is still not seekable , the index has not been created properly or inaccessible for some reason.
Any other help is highly appreciated.
Regards. -
Sometimes it won't work. It depends on your original source file. Sometimes you need a different software program to fix the problem.
http://www.jhepple.com/support/reindexwmv.htm
or
https://www.videohelp.com/forum/archive/asf-wmv-to-avi-mpg-t146174.html
How can I INDEX a .TS file?
By lovelylisa in forum Video ConversionReplies: 9Last Post: 7th Jun 2011, 15:48 -
WMV file cannot fast-forward
By joelson in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2008, 11:46 -
Output File videwo way too fast (WMV to MP4)
By TenaciousH in forum Video ConversionReplies: 2Last Post: 14th Feb 2008, 18:53 -
How ro re-index faulty WMV files?
By seymoria in forum RestorationReplies: 7Last Post: 17th Jan 2008, 08:00 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
