Hi,
I was wondering what best software for converting avi to mpeg4 was. I tried Videora, but it was painfully slow. So, I'm looking for something fast.
PLEASE give us as much information as possible and it's MUCH easier to help.
Do you want to convert to a format for you portable device? what then?
Because just mpeg4 can be avi divx,xvid or h264 or a mp4 with divx,xvid h264, etc. -
From what format to what format? AVI and MPEG4 doesn't tell us much. Which codecs are you using?
Is this for a portable device? If so, here are some other converters and programs: https://www.videohelp.com/tools/sections/portable-mobile-psp-ipod But you could probably try SUPER.
Any encoding is CPU intensive and your CPU speed is what determines how long it will take. Some codecs are faster than others. If you are using H264 or similar for a final format, it will be slow, no matter which program you use.
And welcome to our forums.
I want to convert it to mp4 so that I can play them on ipod and PS3. I think the following are the supported mp4 for PS3:
* MPEG-4 SP (AAC LC)
* H.264/MPEG-4 AVC Main Profile (AAC LC)
In terms of the files I have, I'm not entirely sure, as I just downloaded them. I think some are divx and some xvid
Would this info help you narrow it down at all?
What is the best current AVI to MPEG 2 converting software?
By avz10 in forum Video ConversionReplies: 8Last Post: 2nd May 2012, 17:00 -
Converting NVC files to AVI or MPEG4
By ski1hunt in forum Video ConversionReplies: 1Last Post: 15th Feb 2011, 08:24 -
help converting mpeg4 to avi
By gcross26 in forum Video ConversionReplies: 1Last Post: 10th Oct 2010, 14:07 -
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 06:44 -
Converting 3gp to MPEG4 .AVI
By vworley in forum ffmpegX general discussionReplies: 9Last Post: 2nd Apr 2008, 12:48
