Is there a simple app i can use to join 2 or more .FLV files. They have the same frame rate, dimensions, etc. I dont want any reprocessing of the file, just a clean join. Surprisngly i've found this to be very difficult to find; to me joinging means stripping the headers off files 2 and onward and modifying file 1's header to reflect the new video frames. Maybe im missing something when it comes to FLV, whereas every other format seems to do it the correct way. Then again maybe im just finding crappy flv joiners.
Results 1 to 30 of 50
I haven't not seen any such easy tool yet.
You could use flv extract, https://forum.videohelp.com/topic334748.html#1738560 , no conversion in the joining but I have no idea how you would multiplex it back from the avi to flv without conversion.
It worked with a flv clip from youtube and Media Player Classic identifies the runtime correct. I will see if it works in a flash media player also.Originally Posted by Placio74
Yes. :POriginally Posted by Baldrick
I'm try Movica 0.6.1.5.
Not see .flv extension in Join (Select file to join), but i'm add files manually.Beta 0.6:
New formats that are now supported
- Flash Video - using the open source tool flvtool
- RealMedia Video - using rmeditor from Real
Possible success (not for all FLV's).
I have version 0.6.1.5 - it says this is the most recent?
Where does version 0.6.2.1 come from? -
Are you kidding?Originally Posted by Seraph
Videohelp.com > Tools > Movica.
Or http://sourceforge.net/project/showfiles.php?group_id=169161 -
Unfortunately Movica used WMP (DirectShow) to play.Originally Posted by Seraph
You have installed FLV Splitter and ffdshow (with turn-on FLV1 and VP6F)? -
Yes, I have.
I can probably live with not be able to play my flvs in Movica.
However, more irritating, is that when playing my joined flv in FLVPLayer, the controls only work for the FIRST of the joined videos.
So you can't forward beyond the first video of the joined file - thus the time line only works for the first video of the joined file.
Any ideas why? -
Have you tried join with latest avidemux, http://mulder.dummwiedeutsch.de/home/?page=projects#avidemux ? Same problem or?
I'm confrim for Flash Player and VLC.Originally Posted by Seraph
Exclude FLV Splitter + ffdshow and some DirectShow player.
After join files in Avidemux - OK.
After join files in Movica and later remux used FFmpeg or Avidemux - OK.
Simple.Originally Posted by Seraph
Download latest Avidemux build.
Open first file,
File > Append next file,
choose container (Format) FLV,
Video & Audio is default Copy,
Save (type name new file and extension). -
Yes. But, it's concerns FLV with VFR (variable frame rate) - not all FLV's.Originally Posted by Seraph
Unfortunately, at this moment... -
I'm look into output file.Originally Posted by Seraph
Movica (FLVTool) leave both headers and not change metadata info (play time, ...).
Well, after remux used FFmpeg (from command line) or Avidemux (but possible problems with VFR) stay only one header and change metadata.
Flash Player just read play time from metadata (not calculate) from first header. -
Use FLV Knife (GUI for FLVTool).
(Can use FLV Knife to cut FLVF's.)
FLV Splitter + ffdshow + DirectShow player = OK,
MPLayer = OK,
Flash Player = OK,
VLC = fail, can't play this file
Well, Movica it's still beta and support for FLV is fresh.
I'm think it's bug - Movica use FLVTool too.
Waiting for next release... -
I'm see new version Movica.
Unfortunately, still problem with correct metadata.
FLV Merge - it's simple command line tool.
Output file - merge.flvCode:FLVMerge.exe 1.flv 2.flv
And... metadata not correct.
At this site i'm find FLV2MKV (can join FLV's and mux to MKV) - it's mix FLV Extract and mkvmerge.
Other...
Instead FLV Knife can use FLV MetaData Injector.
(It work for me - Movica or FLV Merge > FLV MetaData Injector.)
At this site i'm find FLV MetaData Viewer.
And some other...
Latest VirtualDub can use API input plugins.
At this moment exist plugins for: MPEG-2, WMV, QuickTime (MOV, MP4, 3GP) and FLV.
VD + FLV plugin = can open FLV and recompress or only save to AVI.
(VD not support VFR.)
http://forums.virtualdub.org/index.php?&act=ST&f=7&t=14639 -
Greetings from Movica.
Stumbled on this thread quite by accident and learnt of the trouble with the flv metadata. This is a problem for flv players. The directshow approach should not create problem in players in MPC, WMP, Movica, etc.
Have released a version of Movica today that will fix the problem for joins. Edits of flv were already updating the metadata.
Although I will now try and monitor this forum for Movica issues, please do not hesitate to file such problems on the Movica tracker on Sourceforge.
Movica will not detect this version automatically till Nov 14. -
Greetings. :P
Confirmation, fixed.Have released a version of Movica today that will fix the problem for joins. Edits of flv were already updating the metadata.
Hmm... not only - VLC.This is a problem for flv players.
But after used latest version Movica - no problem.
Thanks!
Probably some odd problems with slider (from first joined part to next) in SMPlayer. -
I just tried using Movica, with ffdshow and flvsplitter installed. And it won't open my FLV file =(
I have joined quite a few flv files with considerable success combining the use of 2 command line utilities - flvmerge.exe and flvtools.exe. Although flvmerge alone will enable you to join flv files, it however does not check the integrity of the flv files to be joined. So, if any of the flv files has a flaw, the resultant merged file will likely not be able to play to its end. Another notable setback of flvmerge is its inability to readjust the timecode to the combined length of the video. To overcome these shortfalls, you will have to use flvtool2 which not only allows you to check file integrity but also corrects the timecode problem that is generated by flvmerge.
The entire procedure I use to combine flv files is as follows. It is a bit cumbersome but does produce very good results:
- 1. First, copy and paste flvmerge.exe and flvtool2.exe into the folder containing flv files to be joined.
2. Enter Windows Command Line interpreter, ie Run followed by cmd and Enter.
3. Change directory (CD) to the flv folder.
4. Use flvtool2 to check integrity of flv files to be joined: Flvtool2 -D video1.flv. Repeat this for remaining flv files.
5. Now join the flv files using Flvmerge: flvmerge video1.flv video2.flv .... videon.flv. The output video is named merge.flv by default.
6. Readjust timecode of combined video: flvtool2 -U merge.flv
Hope this helps. - 1. First, copy and paste flvmerge.exe and flvtool2.exe into the folder containing flv files to be joined.
Annoying 'gap sound' when joining flv files
By KeyMs92 in forum EditingReplies: 2Last Post: 17th Sep 2011, 20:31 -
joining tools (preferably with flv/mov support + others)
By lordrt in forum EditingReplies: 3Last Post: 20th Aug 2010, 11:53 -
Joining multiple FLV files into one?
By Super Warrior in forum EditingReplies: 2Last Post: 30th Jan 2009, 23:42 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 22:32 -
Joining FLV files together
By DRP in forum EditingReplies: 8Last Post: 27th Oct 2007, 21:07
Latest beta 0.6.2.1?
