I am looking for something that can capture video to my pc with component video or HDMI/DVI input.
Is the "PYRO A /V Link" a good choice?
http://www.adstech.com/products/API-558-EFS/intro/API-558_intro.asp?pid=API-558-EFS
Please share your experience if you have used this product or if you have other component video capture options.
Thanks!
I have an older Rev.C of this device. It works fine for 480i sources. It does not support 480p or higher resolutions.
This is my setup:
Source --- DMR-ES10 === ADS Pyro
or
Source === ADS pyro
Where:
--- > composite/s-video
=== > component
I use the Panasonic DMR-ES10 as a sync filter and composite/s-video upconverter to component. -
I also have a REV C, and I love mine. I only use it to transfer VHS to my pc as DV-AVI. For all of my other video, I transfer straight from the camera to an ADS Firewire PCI card in my pc.
Rob
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 23:40 -
ADS Pyro A/V Link - black screen
By Brad in forum Capturing and VCRReplies: 10Last Post: 20th Oct 2010, 20:23 -
VHS into Imovie (HD6) with Pyro AV Link Problem
By MacInMass in forum MacReplies: 3Last Post: 9th Apr 2009, 09:25 -
Pyro A/V Link w/Elements not recognised by Vista 32bit
By hhhgamewmx7 in forum Capturing and VCRReplies: 12Last Post: 1st May 2008, 20:51 -
Is Pyro's S-video output an accurate representation of capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2007, 17:41
