I have Vegas 6 and want to make MPEG4 video.
I can see this under "make Quicktime mov" and then choose the option MPEG4 Video.
However, it renders it as a MOV file and I change the extension to MP4, but it doesn't work.
Says wrong file type or something like that.
Any ideas anyone?
mp4 and mpeg4 video is not the same. mp4 is a container for video and audio and mpeg4 video is the video. BUt I guess you want a mp4 with mpeg4 video(divx,xvid or h264).
I don't think vegas supports the mp4 container. You can export to avi with mpeg4 video(divx,xvid,h264) and then use YAMB to make a mp4. -
My version of Vegas 6 has a "Render As" option "Sony AVC/AAC (*.mp4).
Using the Default Template (Audio 128kbps 48,000Hz, AAC - Video 512Kbps, 29.97, 320x240) I get a small mp4 file. GSpot tells me "not a valid AVI File" and "Rendering failed" under Direct Show Render.
There are other templates available - I haven't had time to experiment yet. I just use it for the occasional quick check print of my project.
The file will play in VLC, but if I use the slider to jump ahead, VLC gets confused. The audio jumps ahead and plays but the video stays on the last frame and does not progress.
Need help making 3D bluray with Sony Vegas 11
By Ivo1977 in forum EditingReplies: 0Last Post: 2nd Mar 2012, 03:52 -
Sony Vegas MP4 problem
By Abas-Avara in forum EditingReplies: 27Last Post: 14th Feb 2010, 12:19 -
Making movie in Vegas from MPG files
By malexi in forum Newbie / General discussionsReplies: 11Last Post: 22nd Jul 2009, 09:05 -
Can't open mp4's in Sony Vegas
By ClownInBrown in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2009, 14:43 -
Making global changes to Vegas 7 subtitles
By TKB in forum SubtitleReplies: 2Last Post: 19th Jul 2007, 10:54
