Presently i have a gsa-h22l drive i have Philips 8.5 gig disks that are 8x -- my gsa-h22l well only do 2.4x burn for these disk way to slow for me.. I got a lg(gsa-h55l) it claims it burns the dual layer disks at 10x ..my 8x disks would only go at 4x the only reason i got the new drive was for the speed so i returned the drive...and got a lg(gsa-e40l) external usb drive.... it well only burn them at 2.4x...so all be returning that drive as well... can anyone recomend a drive that well actually burn them at the proper speed...i know some brands and some drives get different results with speeds with the 4.7 gig disks... but the dual layer disks are way to expensive to try different brands with...for example the philips 25 pack 8x dual layer disks i have sell for $84.00... they cost more than the burner...can anyone reccomend a make and model of drive that should resolve my issue...
Results 1 to 9 of 9
To my friend, my mate, my love, my queen - the honour is to serve
I would never burn DLs faster then 2.4x anyway.
I use the best, Verbatims. -
Burn speed is controlled via the drives firmware. Most likely, the discs you are trying to use are new or not part of the firmware in the drives you were trying to use, so the drives default to the slowest speed. A firmware update likely would have corrected the issue.
And FWIW, you also may want to change your choice in media. The only reliable brand available at the moment is Verbatim. I've tried Playo, Matrix, Memorex, Ritek, and Verbatim. Verbatim discs are the only brand to successfully burn and pass testing error free. These were all tested using a NEC 3520a and Pioneer 112D burners both using the latest firmware and various burning speeds.Google is your Friend -
Pioneer
6x max suggested, 4x preferred
Verbatim media only, nothing elseWant my help? Ask here! (not via PM!)
thanks for the suggestion on media all try to get some verbatim...i did try upgrading to the latest firmware as you said krispy but with no luck...mabe a change for media well help...but setting media aside can anyone suggest a good reliable burner for the dual layer disks
To my friend, my mate, my love, my queen - the honour is to serve -
Pioneer DVR-111, 112 or the SATA cousin 212. You won't go wrong any of them.
I have the Pio 112d and burn Verb DL disc with excellent results. I have burned at 8x with no problem but would slow it down to insure better quality.
I would also suggest burning with imgburn(freeware) as you can select the layer break point. You dont want a brief pause in the middle of a fast moving scene.
Pio burner, Verb media, ImgBurn software, you wont be disappointed. -
thanks for the suggestion all chk out the pioneer...
layer break point?To my friend, my mate, my love, my queen - the honour is to serve
Double layer DVD-can I burn 2hr at Highest quality?
By jbitakis in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2011, 12:59 -
Double Layer Issue That Is Beyond Bizzare..I think I killed the burner
By mrjoelabs in forum DVD RippingReplies: 5Last Post: 1st Sep 2010, 09:49 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Need to burn my first double layer dvd EVER.... HELP !!!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 25th Mar 2009, 17:42 -
How do I burn double layer disc with Nero 9
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2009, 06:13
