(Yes, I got permission to repost this w/o the offending info)
I'm getting this with several files I'm trying to extract the audio from in full processing mode in VirtualDubMod. They're all XviD AVIs with VBR MP3 (average 128 kbps) audio. Is there anything I can do to fix it? I want to be able to do good conversions to DVD w/ TMPGEnc & DGPulldown instead of using an all-in-one suite like Nero Recode, but this throws a wrench into those plans.
Is there any way to fix this?
Thanks!
Try using VirtualDub Mp3 Freeze. It's designed to handle VBR audio. Avidemux works very well too.
Installing LAME ACM and trying VirtualDub MP3 Freeze didn't work, but AVIDemux did. I saved the stream in an MP3 container, but the headers were messed up, so I ran the MP3 through VBRFix, and then took *that* MP3 and decompressed it to LPCM WAV in WinLAME.
Thanks for the suggestions
Stylized "RW" logo found on blank media packaging - what does it mean?
By ibzomie in forum MediaReplies: 3Last Post: 30th Dec 2011, 08:48 -
AVStoDVD does not start... says "VB6 Common Controls not found!"
By granturissimus in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2011, 08:15 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05 -
virtualdubmod EXample file for "import chapter" function?
By KneeRow in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2009, 12:07 -
"No audio decompressor could be found..." in VirtualDubMod?
By Bix in forum Video ConversionReplies: 2Last Post: 6th Sep 2007, 17:18
