Hello all,
I recently upgraded my PC and while rendering a project (DV to CBR MGEG-2), I've noticed that my CPU seems to be under utilized as task manager reports only 20%-40% of my CPU being used.
I am running Sony Vegas 7.0e and have a quad core Q6600 processor with 2 GB of RAM (also running Vista).
Any insight into this problem, or is this normal?
Thanks.
If you're frame serving that's pretty common. Often the bottleneck is coming from Vegas sending frames to the Mpeg encoder. It isn't really Vegas specific, lots of apps do this. You can test it by rendering to a lossless codec like Huffyuv, then encoding the resulting AVI in your Mpeg2 encoder. If the CPU utilization increases and the Mpeg2 encoding time is faster, you'll have identified the bottleneck.
cpu vs gpu for video rendering with i5 460m 2.53 ghz
By Edgarke16 in forum Software PlayingReplies: 6Last Post: 3rd Jan 2012, 06:43 -
Vegas rendering - Low cpu usage on 8-core
By lapoune in forum Video ConversionReplies: 5Last Post: 2nd Jun 2008, 11:07 -
Rendering nested project only uses half of the CPU - Sony Vegas
By tarrickb in forum EditingReplies: 0Last Post: 16th Aug 2007, 13:25 -
By tarrickb in forum Video ConversionReplies: 0Last Post: 16th Aug 2007, 09:47 -
CPU usage while rendering (and taskmanager display)
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 5th Aug 2007, 12:05
