  1. Not sure which forum to post this so I'll start here. A friend of mine uses Windows Media Center and he saved a football game from his TV tuner which is in .dvr-ms format and is 4hrs long and 12 gigs in size. Is there anyway though WMC to burn this file to a single dvd? Or is going to have to get some 3rd party software to do this task? If 3rd party is needed what do you recommend?
    Sep 2007
    Boston, United States
    Probably the .dvr-ms is DRM protected so your best best is to use video out and capture the stream on your PC.
    Have you tried DVRMSToolbox ?
    Tmpgenc xpress supports dvr-ms and can convert to dvd(not drm protected though).
