Okay here goes. I have burned many vcd's using nero. They will play on my PC dvd player. But when attempting to play them on my home DVD player, I get disc error. I thought it was my player, but I purchased a VCD and it played without problem. So my question is. Is there a problem with burning a disc using nero on WinXP or is it the disc itself.
hey man...I had the same problem as u.....first of all check the bottom of ur cd..if the cd bottom part is either blue or green home dvd players can't read them......burn em on gold or silver cd's....they'll work
hi,
it depends on the DVD player you have. check wether they have compatiblity with CDR playing. if it is sony most dont play CDR's. try to use a CDRW. most dvd player palyes CDRW
Baskaran
baskaran@yahoo.com -
That blue or green comment is pretty much way off. The easiest way to see what your player can play is by reading the compatibility guide to the left. Most DVD players can play vcd's..............but they have to be on cdrw's.........NOT CDR. Some players do play on CDR's, but your best bet is a cdrw
will .vob files alone play in a home dvd player?
By vincy in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2012, 05:04 -
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 18:52 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 06:12 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 20:59 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 15:26
