I have an MPEG2 that I want to cut some things out of and then burn to DVD. I've heard TMPGEnc MPEG Tools will do this without re-encoding, is this true? Does anyone know if Ulead Video Studio 11 will do this without re-encoding? Thanks
If the mpg is already DVD compliant (it has to be, or else the whole mpg has to be reencoded anyway) I'd just load it into TMPGEnc DVD Author and remove the unwanted parts there. Done it many times to remove commercials from TV recordings.
/Mats -
If you use VideoReDo or MPEGVCR to make your edits (both are free to "try before you buy" for something like 30 days), they will not re-encode your video. You will have to reauthor the DVD after any editing though. It would pretty simple to do this with MuxMan. TMPGenc DVD Author would be another tool you could use, as Mats suggested. I would not recommend using regular old TMPGenc (just the encoder) and it's MPEG Tools for this. Yes, you can do that, but some people like me have terrible audio sync problems after editing with TMPGenc. You may or may not, but be aware of the possibility. This kind of thing was part of the reason that I bought MPEGVCR years ago to do MPEG edits.
There is also MPEG Video Wizard from Womble. For cutting Mpeg2 you have lots of choices like fading video and audio, make transition in a splice and so on.
It will re encode only changes not the rest of the file. -
What is a DVD compliant MPG? I'm guessing MPEG2, 720x480, 29.97 fps, VBR with a max video Bitrate of 7 Mb/s. Am I missing anything?
That's basically it. Add some GOP length restrictions, audio format restrictions, and we're home free.
Look here for a complete rundown
/Mats
Re-encoding HD MPEG2 video
By txporter in forum Video ConversionReplies: 27Last Post: 6th Mar 2010, 07:01 -
Analyze MPEG2 from DVD to see if 2-pass encoding was used
By motown01 in forum EditingReplies: 8Last Post: 7th Oct 2009, 22:33 -
Edit MPEG2 video without encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2009, 14:05 -
How to cut/trim HD-MPEG2 without encoding?
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 27th May 2007, 18:50 -
Regarding MPEG2 Encoding (DVD authoring)
By Wuhtzu in forum Video ConversionReplies: 9Last Post: 10th May 2007, 18:07
